- Joined
- Oct 1, 2008
- Threads
- 24
- Messages
- 311
Hi All,
I just unexpectedly bought an 1996 FZJ80 (locked) while the wife, kids and I were 600 miles from home (darn Craigslist). Anyway, I was getting MAJOR noise while turning and serious washboard vibrations when I backed off the pedal (up around 65mph). From lurking on here so much, my first thought was the spindle bushings were dry so I redid those in a Hampton Inn parking lot over a half day while the wife and kids enjoyed the pool. Unfortunately, the noise stayed but the time wasn't completely wasted because I put some grease in the bushings and the birf housing.
After another 150 miles and increased noise, I pulled over in a Target parking lot, jacked up the front end, rotated the tires back and forth, and saw that the U-Joint had MAJOR movement. So much so that I figured I had just a few more miles and it would've broken the cap and the driveshaft would have fallen to the pavement(not good at 65 mph). Not having a vise or a press, I pulled the front driveshaft, threw it in the back, and the vibrations and noise disappeared.
Now, if I understand the function of the VC correctly, I should not have been able to drive away without first getting the VC warmed up (some have called it a humping period). In my case though, as soon as I pushed the throttle the LC instantly moved. Just to add, when I crawled under the truck prior to purchasing it, I noticed what seemed like fresh orange sealant on the T/C. Also, I do not yet have a CDL switch installed so it should have been unlocked (Hi range).
So does this mean that
A) My VC is not functioning correctly
B) My VC has been removed
Also to add, I've searched the topic and couldn't find a straightforward error. My apologies if a similar thread exists and I'm too newb to find it.
