Definitive VC Question
Hi All,
I just unexpectedly bought an 1996 FZJ80 (locked) while the wife, kids and I were 600 miles from home (darn Craigslist). Anyway, I was getting MAJOR noise while turning and serious washboard vibrations when I backed off the pedal (up around 65mph). From lurking on here so much, my first thought was the spindle bushings were dry so I redid those in a Hampton Inn parking lot over a half day while the wife and kids enjoyed the pool. Unfortunately, the noise stayed but the time wasn't completely wasted because I put some grease in the bushings and the birf housing.
After another 150 miles and increased noise, I pulled over in a Target parking lot, jacked up the front end, rotated the tires back and forth, and saw that the U-Joint had MAJOR movement. So much so that I figured I had just a few more miles and it would've broken the cap and the driveshaft would have fallen to the pavement(not good at 65 mph). Not having a vise or a press, I pulled the front driveshaft, threw it in the back, and the vibrations and noise disappeared.
Now, if I understand the function of the VC correctly, I should not have been able to drive away without first getting the VC warmed up (some have called it a humping period). In my case though, as soon as I pushed the throttle the LC instantly moved. Just to add, when I crawled under the truck prior to purchasing it, I noticed what seemed like fresh orange sealant on the T/C. Also, I do not yet have a CDL switch installed so it should have been unlocked (Hi range).
So does this mean that
A) My VC is not functioning correctly
B) My VC has been removed
Also to add, I've searched the topic and couldn't find a straightforward error. My apologies if a similar thread exists and I'm too newb to find it.
It does not mean that your vc is not working properly. If you continue to drive it without the front shaft and without locking your tcase via the centre diff lock and the 7 pin mod, it will destroy itself trying to keep the truck moving.
So are you still on the road? If so, you may be able to hotwire your truck so that it locks the centre diff and not have to buy a switch. Try this link:
https://forum.ih8mud.com/80-series-...ferential-actuation-using-wiring-harness.html
The look of fresh sealant could mean anything and nothing. It could be that a chunk of dirt fell off, or maybe someone had a new seal put in.
This is my point, there was no discernible difference in how much pedal pressure it took to get the truck to move. Nor was there any period of having the engine rev and then the truck slowly start moving. It seems like if it was working to keep the truck moving, there would have been some difference in operation. If anything, it moves quicker without the front driveshaft than with.
If it had been removed you wouldn't have moved at all.
Curtis
So is it safe to say that a Landcruiser with:
A)No front DS, center diff unlocked, and no VC - Will not move
B)No rear DS, center diff unlocked, and no VC - Will not move
C)No front DS, center diff unlocked, VC - Will move but will take more effort due to the VC having to spin and create inertia (may not be the right word)
D)No rear DS, center diff unlocked, VC - Will move but will take more effort due to the VC having to spin and create inertia (may not be the right word)
E)No front DS, center diff locked, no VC - Vehicle will move
F)No rear DS, center diff locked, no VC - Vehile will move
G)No front DS, center diff locked, VC - Vehicle will move
H)No rear DS, center diff locked, VC - Vehicle will move
Where does this leave me?
No front DS, no CDL, not sure about VC - Vehicle moved normally and if anything, took less effort. <--This seems to indicate that my VC was locked up from the start and wasn't functioning correctly when I bought it.
A)No front DS, no CDL, and no VC - Will not move
B)No rear DS, no CDL, and no VC - Will not move
C)No front DS, no CDL, VC - Will move but will take more effort due to the VC having to spin and create inertia (may not be the right word)
D)No rear DS, no CDL, VC - Will move but will take more effort due to the VC having to spin and create inertia (may not be the right word)
E)No front DS, CDL, no VC - Vehicle will move
F)No rear DS, CDL, no VC - Vehile will move
G)No front DS, CDL, VC - Vehicle will move
H)No rear DS, CDL, VC - Vehicle will move
All correct, although instead of "no CDL" it would be more clear to say "center diff. not locked", and instead of later just saying "CDL", you should say "center diff. locked" (which of course would require a switch if in Hi).
You're VC *might* be seized. You probably ran across methods for testing this during your search?
Curtis
I wont claim to be an "expert" on this. Here are my views though:
A: correct
B: correct
C: partly correct, in my experience the vc needs only about 0.25-0.5 rotations to viscously lock up. It will always have some slip though. As I recall its about 80% efficient at locking up, in other words, your front output shaft will still spin at a different speed than the rear.
D: as above in C
E: correct
F: correct
G: correct
H: correct
There are other tests to confirm the operation of your VC. Turning in tight circles on hard packed dirt with a seized vc will make the truck feel like its pushing. If you feel no difference between the truck in high and Low at low speeds then the vc, or an associated switch might be the culprit.
Curtis
Good call on the changes Curtis, I corrected my earlier post for easier understanding.
As for testing, I didn't remember how to do it when I was in the parking lots wrenching but I plan to install new Ujoints tonight and I'll see what happens.
I tried this when I test drove it prior to purchasing, I was paying more attention to the front axle locking up than the VC though. I'll follow your advice tonight and see what's what.
A VC rig with the front DS out will move, run, it will feel like the torque converter is slipping, more so when starting from a stop, reducing as the rig speeds up. If run long term there is a chance of overheating and locking up the VC.
Locking the center diff lock is easy, even without the switch. Start the rig, shift the trans to N, shift the transfer to L, the CDL and ABS lights should come on, remove the locker fuse, shift the transfer to high and drive. To unlock, simply replace the fuse, the CDL will stay locked as long as the fuse is out.
That is what I was expecting but it didn't do that at all, that's why I think the VC could be done for. I'll test tonight and post up the results, hopefully it's just that my VC is very subtle and I didn't give the feel I expected. Doubtful but there's nothing wrong with positive thinking.
If the drive shaft is out, it's easy to check. Unlock the CDL, shift the trans into park and try to push the rig. If it's good it will roll, with some drag, that will increase as it rolls. If it's locked it wont roll, you will be able to rock it back and forth locked on the park pawl. Be careful parking the rig with the shaft out and the CDL unlocked, even if you think the VC is locked it could slip and the rig roll.
If you live where there is snow, slop, the VC is nice to have. Where I live there pretty much worthless, so if/when mine takes a dump, it will be removed. Removing is relatively easy and the only driving difference the lack if VC limited slip.
I have one that's locked, don't know how it got that way, the rig was purchased with it locked. "Net knowledge" says they are weak, prone to failure, but a couple of locals have pulled shafts and driven around town, one including some highway speed, with no apparent failure signs.
... I noticed what seemed like fresh orange sealant on the T/C. ...
The factory used orange silicone looking sealant on the transfer. On some rigs, I have seen it look like new, when in fact it is from the factory.
I am not fond of mine. I can feel it when it engages when its slippery (icy and dirt roads) and I am fooling around and stunting. I have found that with the cdl engaged I get more predictable behavior out my truck than when I let the vc do its thing. I find that it leads to fishtailing. With the cdl engaged the truck tends to walk sideways though.
My wife's is locked up, and will chirp the tires on pavement when turning tight. I would expect it to drive fine if I removed a driveshaft without locking the CDL. Mine, on the other hand, is extremely sluggish with only one driveshaft and the CDL unlocked. When I bought it I tried to tow it on a dolly (two wheels on the ground) not knowing about VC's. It went one block before the CDL locked up and the tow rig started having trouble pulling.
I'd guess yours is locked up.
-Spike
Well, the front DS is out and when I push on the back of the truck, it definitely bounces off the parking pawl. I just need to make sure the CDL is unlocked now (don't have a switch and no lights are on so it should be) and I think I'll have confirmed that the VC is locked up. When I refinstall the front D/S I'll test it out on dirt and see if the front end is indeed pushing. I wonder if the locked VC led to the early demise of the front U-joint?
Next question: How long can I drive with a locked VC and the front driveshaft back in? In this case, the locked VC actually helped since I was able to drive home without the front D/S although a CDL switch would have allowed me to do the same.
Purely hypothetical: If someone is planning to run without a front D/S and has no intention of ever using 4wd, is a locked VC more effective than a locked center diffential? If so, why?
My plan of attack: If the VC is found to be bad, I plan to remove it and install the CDL switch and Pin 7 mod (plan to do those either way actually). Once it's removed, what happens if I park the truck without locking the center differential, will the parking pawl stop it or does it have the potential to roll away?
If it doesn’t roll something is locked, most likely the VC if you haven’t locked the CDL. Being locked some bind/additional load is on the drive train, it added to the joint wear, but most likely it’s failure use mostly due to it being dry, lack of maintenance, rarely if ever greased.
I wouldn’t reinstall the shaft until the VC is replaced or removed.
Pretty much the same effect, but with the locked VC, it’s a failed part, so could start slipping at anytime. I wouldn’t count on it, would lock the center to be sure.
If both drive shafts are in, it will have normal operation, except loosing the limited slip function of the VC.
Have a look to see if the cdl fuse is in place. Maybe the previous owner locked the cdl and yanked the fuse.
That was a good read, thanks. That still leaves me with a question though; When the VC is removed, does all the power go to the axle with the least amount of traction? For example, if the rear end is on pure ice and the front end is on solid ground, and the center diff and front/rear axles are unlocked, will just one rear tire spin (tire with least amount of traction out of the four)?
