Decision time.....
Bars
So which one :meh:
I would stay away from any chemical sealant ... I have NEVER heard of one that really worked AND they can foul your rad, water jacket passages and heater core. Stay way from that crap. If you are planning on doing a headgasket anyway -- dont make life worse for yourself by using a stop leak. As far as fixing a leaky birfield ... fwiw it is a walk in the park compared to a headgasket job. You need to do them both....
FWIW, I know of at least a dozen or so guys on here that have used the Bars with carbon fiber in the past two years and have had no problems since. Guys that I respect their opinions on "things" related to Land Cruisers. I know that if I owned a 1FZ-FE (I know this is one of those hypotheticals that is NEVER going to happen but...) I would have to try this if I was in your situation because there is just no chance up me having 3-4 grand laying around to do a motor rebuild. So I would throw $50 and cross my fingers.
On the fence about this move. I'm still losing coolant from the overflow and have ruled out the rear heater lines after inspection. Heat works, rear heat works, and the only signs I'm getting of impending doom is vapor mist briefly upon startup, rough idle for 15 seconds or so on startup, and coolant loss from the resovoir.
I keep running this through my head. I don't know what's been done by the PO. The HG may never have been touched (390K) or maybe the PO already used this stuff or something similar. It's like rolling the dice.
My thought is go ahead and use it. Take care of my knuckle job. Then save for a proper HG job or a straight up engine swap.
Thinking of using the professional grade Bars.
My vote is for Bars HG fix stuff. Qball and numerous others have used it and have had good luck with it. It isn't the same crap that was sold 20 years ago. It's about $50 for a bottle of it.
As for the axle rebuild...If money is tight just keep it filled with moly grease through the fill hole on the back side (square plug on the top). It isn't going to hurt anything. Drive it for a month or so and see how the HG is holding up.
No chance in hell he is repairing your head gasket the right way for $1500. Not a chance. The head needs to be checked for warping or cracking. Then machined. Machining costs about $500 alone.
Spend the extra time working your second job to save up for the HG and knuckle rebuild. Or buy a 3FE and not worry about your HG crapping the bed. :flipoff2:
i actually had an old school indie i trust do it for $1300 and i supply the parts... i got a gasket kit from beno and he went through it, sent the head off and checked it for warps and cracks, all it needed was a resurface, did a valve job at the same time
also had him replace my VSV while he had the intake off, but that's a 2 second job once it's off
we'll see how long it lasts....
I didnt read the entire thread. But HG first all the way. If you keep the axle lubed up it wont hurt anything in the mean time. So just keep it all lubed up. But ignoring a HG and destroy the motor is a big deal. Personally i think 1400 for axle is too high and 1500 for HG is too cheap. I would not do the HG with out having a machine shop redo the head. That should put it up around 2500 for a GOOD shop to do it. Or it should be about 600 in OEM parts and 400 in machine work to do your self. Personally i would not let ANYONE do a HG on my truck except doing it myself or driving south to ACC. In the big scope of things they are not that far from you. Please give them a call and also contact Beno or Sam for parts and a FSM. You are really luck that all those great resources are local to you here in Atlanta/north GA.
PS there is a motor for sale here on mud from a mud motor south of Macon. Seller says it is a good running motor, good price in my opinion. But i have no affiliation with it.
Yeah @slowLC is selling two! Great prices on both. One evidently has a blown head gasket but you could drop it off at Not On Main Street Garage (not too far from you), have them go through it, and then swap it out when yours finally blows. That'll probably save you some cash that you can then use to replace your failing cooling system/heater lines.
So here we go; ran the HG test tonight (couple of times) and I never saw an indication of exhaust fumes in the coolant (yellow color indicator).
Where to go from here? Still use Bars?
No. Isnt your radiator full of sediment? Bars will only add to that. What does your mechanic say? How's your compression? Have you tried using uv dye in the coolant to see where it stains?
Continue base lining all your gaskets, seals, fluids, hoses and belts, etc.
Not sure if it's full of sediment or not. There's sometimes crud accumulated underneath the rad cap so that might be an indicator. New rad etc is on the to do but I've been diligent in trying to confirm if I have a HG leak or not. According to this test I don't.
If that's the case I will turn my attention to the rad and my knuckles. This seems like a pretty solid test indicator.
True but you're still losing coolant somewhere. Maybe it's important, maybe it's not. Dye and a black light might tell you something.
The knuckle rebuild is really easy. Get good parts and knock it out.
That's a hard one, losing coolant and bubble in the overflow are sure sign of HG failure. I'm thinking it's rather small. Personally I would use bar's and see if the Coolant lost stops, you can always flush all that stuff out later at a shop.
If not then you better find your coolant lost, it went somewhere.
I may have found my coolant leak after closely inspecting my heater control valve; looks like coolant is dropping on top of my valve cover gasket and rolling down the side, at least what's not evaporating. It seems to have pooled on the lip of the cover. You can see the stained drip spots.
I'm slowly loosing coolant out of my resevoir only; did the bock test (see above) and did not test positive.
Could this be the source of my slow leak?!
It could be. I would still concentrate on the coolant loss. The Knuckles will be just fine if they are kept lubed for the next week or even month. But if your motor over heats it will be toast in 10 min. If you decide your head gasket is good then i would actually be even more inclined to really focus on the motor. Because then you might actually just have a $5 hose that is leaking. That $5 hose will cost you an entire motor if you ignore it. Now how much would that suck. Keep the birf lubed and sort out the motor. Dont even look for the leak until the motor is good and hot. The coolant system has more pressure when hot and you might just have a leak that only leaks under pressure. Just a thought.
Guess the only thing to do is get it warm and run the heat, monitor the heater control valve for leaking. Looks like coolant pooled up on the lip to me.
