Decision time.....
Heater control valves are a known part to fail. 20 year old plastic that has got coolant running through it. I believe they are about $15-20 to replace...
Could be a super inexpensive ending to the thread. 20 dollar heater valve and 125 dollar seal kit.
This time. Don't worry. This is just the 1FZ-FE's way of luring him in... haha
Yeah, heater control valves are $34. I was a little off. I believe these are the ones that @Tools R Us has been using for years. Hopefully he'll chime in for sure but I'm pretty positive. The Toyota OEM ones are crazy expensive. Normally I'm an OEM guy but the Four Seasons ones have been pretty well tested.
http://www.amazon.com/Four-Seasons-74780-Heater-Valve/dp/B000C2Q98S?tag=ihco-20
I bought a heater contol valve from NAPA "in case" while I have been doing my head gasket ... as it turned out mine "looked" very good and held up to a fair bit of tugging and twisting .. so I am re-using it for now... BUT Toyota Canada wanted $185 for a valve and NAPA sold me one for $65 Cdn.
I note you are using a green coolant ... fwiw good or bad .. I have only used Toyota Red ... and have done several refreshes over the years with 50/50 Red and distilled water ... anti freeze gets a work out in Canada. And we try not to screw around with it -- and use proper mixture for -40
Ran the heater on high for a while today and monitored the HCV; didn't see any signs of seeping :mad:
So not sure what to think now. I inspected the rear heater lines but they look fine. I'm gonna try to check the block for signs of white seepage.
And I guess I'll be sending an oil sample to Blackstone.
I'm using green coolant because that's what was in there when I bought it. I'm superstitious about it. Had a 4R with a lot of miles on it and changed from green to Toyota red; HG blew a couple of weeks later. Maybe that wasnt the cause but after that I just keep inning what's already in.
Still under 200 with some elbow grease. If anyone who doesn't want to get greasy then either sell it or have crazy amount of money.
Been cold here in North GA the last few days do I've been running the heater quite a bit; well now my resevoir is dry.
Before running the heater it was slowly losing resevoir coolant over time; now it's been drained pretty quickly with the heater running.
Still don't see any leaking from the heater control valve though.
Have you looked at your heater core under the dash? Could be slow leaking there if it's rotted out? Check your floorboards for dampness. Just a thought.
Seems like my LX has decided to make this decision easy for me! Cranked it up this morning and there was the usual rough early idle before smoothing out. Typical vapor out the rear. Then vapor turns to what is obviously thicker white smoke. I stand there and monitor for a moment. White smoke gets thicker and a pretty strong drip of water starts out the tailpipe; by now reality is starting to sink in that yes, I have a blown HG :rimshot:
I call my buddy and have him run me over to O'Reillys and pick up BARS. So here we go........
Wow sounds like your HG failure got a lot worse. Should of put Bar's in earlier when the leak was smaller but should of, would of and could of. Good luck with Bar's, sounds like engine is still running can idle for 30 minutes so Bar's should be able to buy you some time.
Again, best of luck.
Followed all the directions; been driving around and so far no issues. I'm going to let it settle more over night and see what happens tomorrow. Keeping my fingers crossed this works :meh:
Still have some pretty good vapor/smoke on start up.......let it idle for about 5 min and then I drove it down the rode and back. Smoke clears up completely. Seems to run fine.
I'm confused now. I'll be driving it most of the day so we'll see what happens :confused:
