Death wobble
Hope you guys can help me out. I changed out all tie rods but when vehicle hits 40mph and any slight bump the whole steering wobbles/shakes. Tires are ok was wondering if could be alignment. When braking it pulls to the right. When driving slight pull to right. Any suggestions. Thanks.
Check panhard rod/ bushings, control arm bushings, tie rod ends, wheel bearing preload, brakes......warped rotors?, ceased piston?, balance tires, alignment and correct adjustment of LSPV valve. If it's not one of these things.......it's something buried in the front end........races pitted, axle bent......on and on.....I have been chasing a wobble too. Happens when braking going down hill at around 40 to 50 mph. It's very frustrating when the problem isn't glaring. I think my issue is LSPV valve being out of adjustment. Working on fixing that now. Good luck.
Grease your spindle bushings and check torque and rubber of panhards etc down there. Torque on wheel bearings? Landtank's front end under faq should help
Checked tie rods, new, stabilizer new. Forgot to mention while driving hear a clicking noise tick tick, like a rock stuck on tire tread but none. Just rebuilt the front end complete w/bearings. Also a note changed the cv and drive flange had to cut down the flange to fit the lock ring. Thanks again. Any suggestions thoughts. One more thing noticing a tow out wear on the right/passenger tire.
So did you recheck everything after rebuilding your front? Did you aggressively grease your spindle? I had this problem and just packed extra in there and problem solved.
True Death Wobble is not alignment. I agree you have some alignment issue working, but id guess there are other issues...In the Jeep world which some items will translate into our vehicles it is always worn, loose improperly installed components. Each time you get the death wobble you have the possibility of damaging the effected and other components more.
Id guess 80% of the of the time its Panhards in the Jeeps / Lateral control rods ... Proper torque is essential, but Id inspect these as death wobble will round out the bolt holes and initiate wobble even with proper torque. Basically the more you drive and get the death wobble you are possibly damaging other components that were not initially damaged. This is why people have such a hard time tracking it down.
Go back to before you had the condition. Did it start just all of a sudden or after the front end build. If it only started after the build, thats your starting point. Simple first....
I'll see if I can find a very extensive checklist for the Jeep that many shops use when faced with this issue. Some of it will be helpful, but a deliberate, one at a time check is essential.
Good luck - You'll find it.
Start with the panhard bushings then check the control arm bushings. If the bushings are shot, properly torqued hardware may not be enough. Loose wheel bearing or out of alignment have never caused DW for me, personally.
Had death wobble on my 2005 dodge 2500 4x4. Turned out that the sorry ass shocks les Schwab sold me were the problem. I installed Bilstein 5100's and no more problems for many miles now.
Read about death wobble on the internet so you understand it from an engineers perspective and you may just answer your own question.
I had this happen last weekend on the way up to Tahoe for some snowboarding. It was a powder day, so I wasn't about to turn around. Slow going...
:lol:
I had previously checked everything before Christmas, bearings, alignment, etc.
I just checked the panhard nutz and the frame side was really loose, and the axle side was snug, but not to spec either. I'll see if that does the trick.
Apparently 100+ miles of Baja washboard and a thousand miles of s***ty interstate takes it's toll on a vehicle. I need to check on what else shook loose on that trip.
Glazed rotors? That was the cause of my death wobble.. Changed all the bushings.. tie rod ends.. rebuilt the front axle... even changed the pan-hard bushings, which where all due for a refresh anyhow.. but it drove me crazy because i'd still get the death wobble even on a very slight braking ..... until a fellow mud member suggested take the disks to be resurfaced.. and slap some new pads on.. They where definitely glazed... Now it drives like a new car.. solid.. no shakes shimmies.. etc..
Same mud member also suggested I stop driving like a retiered 90 yr old and use the brakes with a little more force in future to avoid glazing the disks.. :steer::flipoff2:
Mine traced back to shocks - they were shot. New shocks = no wobble
I had wobble (not quite as intense as some youtube videos) when I hit a bump on the highway.
Turns out my passenger side lower shock mount was off... literally sheered off... also all 4 shocks were shot.
New shocks/springs all around and no more wobble.
I have this pretty bad on the 80 I just purchased at 265k miles I doubt anything has been changed. Is there a kit that has
all the front end bushings or do they have to be ordered separately?
