I'm looking at ordering some dean wheels to replace those, currently, on my FJ45. My current wheels are 108mm bore, 15x7, -6mm offset and 3.75in backspacing. Of these two wheel sizes, the -5 offset would be ideal ( I a.so like skinnier wheels), but I worry about it clearing the 106.2mm bore. IIRC, this is getting much closer to the stock hub bore size. What do y'all think?
I suppose maybe the +15 offset variant would look similar in stance to the 6.5 because it is further inset, but I'm unsure if it will rub, given my current setup sits further out. Running BFG MT 33 x10.5. My new tires will be a nearly identical in size, just slightly narrower.
I should add, my truck has a 2" OME lift.
