With non-crazy tires, a reasonable load, and reasonable highway speeds, you should be able to reach 13mpg. That's a 30% increase. Pretending that's not significant is ridiculous and defeatist.
We do have some great wheeling up north, but even for us who live in the cities it's a 4hr drive. It's called Iron Range Offroad recreation area (state owned).I thought there might be some up around the Great Lakes
I were to guess, maybe
Very true. 2-3 mpg in these do make a big difference.With non-crazy tires, a reasonable load, and reasonable highway speeds, you should be able to reach 13mpg. That's a 30% increase. Pretending that's not significant is ridiculous and defeatist.
The only thing that would prevent a Land Cruiser from being "rescued" is severe rust/structural damage.Since op asked, my fast forward hot take is your 80 is a very tired 80 and a poor example of how it should drive and perform. To get it back to even near the vicinity of a sorted 80 is easily a five digit endeavor, 6+ months of sourcing parts, plenty o’ ih8 search engine queries + wrench time.
The very fact that it’s in the condition it’s in is merely evidence of the vicious cycle and race to bottom of no budget, no time, no interest in upkeep. I’m not sure this example has hope of being rescued.
Please don’t take this personally. If anything, go crazy and prove me wrong. Good luck.
Your rig is similar now, to my '94 that I've owned since 1998, bought used with 125K miles on it - just under 300K now. It was stock when I got it and I've made a few changes, most of them have had a negative effect on mpg....For anyone curious, I switched tires last week and noticed a significant change.
Old tires were DynaPro MT's in 315 weighing 73 lbs a piece.
New tires are Cooper AT3 XLT in 315 at 62lbs a piece. AT tires make much for sense for the purpose of the vehicle - good siping is a must.
So far through several tanks of fuel I went from an average of 10.1 MPG to 12.7 MPG (mixed driving). That would be a 26% increase.
There are lots of formulas and opinions on tire weight and rolling resistance.. all I know is it does appear to make a difference.
Yes it is. That certainly won’t be undone.. wonder how much added drag there is with the rough surface? Curious, anyway.
If you had bought a stock rig and decided to build it up for touring, would you baulk at spending money to add suspension and gearing to suit your needs?
Think about changes as modding the rig, not de-modding. Does that change your thoughts?
Run a ad for a swap, there's bound to be someone that will trade you for stock gears.It makes it feel less painful in a way. Hindsight being 20-20 I would have bought a stock one, but you don't know what you don't know.. All my hours in baselining and learning about 80's got me the knowledge to know that. Changing gears and everything for maybe 1-2 MPGs isn't worth the effort in my mind. I think we will just drive it at long as we can! Getting rid of the mud tires has definitely improved road manners, and I'm thinking some Dobinsons 1.75 progressive coils with the IMS shocks might do the trick.
just a data point ime...So does my '94 with 265/75R16s (slightly narrower and taller than stock) around town. If you're getting that with consistent highway driving then it's a problem.
Sounds like you should find someone with a stock rig who wants to mount 37s+ and swap the 3rds out of your axles.
Sounds like going stock will be a lot of work with minimal gains (mileage wise). I might look into different tires to improve on road drive ability which may also help economy a little.
Anyone here drive the Alcan highway? I wonder if a 200 mile range is enough to make it to AK? May need an aux tank after all.
