De-flare front 1994
I've got the back flares off. i tried to search the archives for specific guidance on removing the front fender flares. I could not find anything on how to access the nuts on the inside of the front flares.
Anybody recall the specific location of the nuts that have to be removed on the front flares, and how to get at 'em ?
Remove the front corner lights which are held in place by one Phillips screw. Use a flashlight to see the nut locations. Access them through the corner light location and the inside fender access cutouts located inside the engine bay.
From my write up on Durabak'ing my flares years ago on my '94:
The front ones have a screw on each end of the flare and three bolts. The front two bolts are accessed by removing the front turn signal. It's held on by one screw in the engine bay. Remove the screw and gently pull the turn signal straight out. You have to reach in thru that opening to access two of the nuts. The rearmost nut you can get to via the opening in the side of the engine bay.
