In post 3 of this thread there are several pdf files with good information about the combination meter function and connections. Your problem could be a loose connection, so you might want to look at the CM connection pdf. It’s a safe guess the odometer miles are stored in the combination meter.Oh funny thing is a used 2nd hand combination meter assy with over 200000 km asking for 1500ausd wat a rip off. Anyone else had to repair or replace combination meter assy i would like to know. Anyone knows where the odometer mileage is stored on the instrument cluster itself or pcm or some other module?
EDIT: solution here
I am working on trying to add MTS/Turn-Assist (OTA) to my 2010 LX. I've swapped the skid-control ECU/master cylinder, switch panel, and combination meter (gauge). No error codes/DTC, zero-point calibration all done. I had to repin the skid-control ECU, and run 2 new wires to the switch panel.
I now how 5 speed crawl. When I'm in 4LO and hit crawl, the menu appears, and I can scroll through it. I can do...
- nwfl4runner
- Forum: 200-Series Cruisers
