Dash pad removal
Anyone have some tips on how to remove the upper dash pad? I removed the screws but cant get it to come off.
No feasible way to do this without tilting windshield forward?
I've never tried it and can't imagine doing it without window forward. The slots where the clip slides into really need to be accessed from the front with a screwdriver without jacking the clip and the slots up (They are tough sometimes even with a screwdriver and the window forward. They tend to rust and grit).
The other problem I think people have run across is when they "pull on" the dash vs. using the screwdriver to push the clip up, they pull the metal insert out of the dash.
In the Picture below #24 is screwed into a metal insert on #3 the upper dash. #24 slides down into #99. One has to use the flat blade of the screwdriver to separate #24 from #99.
