Dash Lights
Sherwood, Oregon
I am new to the LC's. I purchased a 91 FJ80 a few weeks ago and other then a few small-medium things, I love it! The other day my tail lights (and brake lights), dash light, shift lock over ride stopped working. I replaced the relay for the tail lights and all is working now except for one thing. On the dash is the P R N D 3 2 L and the light around the D is working intermittently...has anyone had this happen before. I don't know much about cars but I sure am learning alot
Welcome!
And, welcome to the "D" club! There is a thread in this forum, which is dedicated to those who have lost there illuminated "D," as this is a common failure, apparently (mine is not lit as well).
EDIT: Here it is: https://forum.ih8mud.com/80-series-tech/195385-no-d-club.html
If it is the D light on the dashboard that is working intermittantly, then it is most likely not the bulb. With the shifter in DRIVE, slightly rock the shifter back and forth towards R and N and see if the light follows. This indicates a failure with the neutral start switch on the left side of the transmission.
There are spring loaded contacts inside this switch and once they fail you will be stranded at the local Chinese take out place on a Wednesday evening, unable to crank the starter.
