dash lights out
Rio Rancho, NM
Any body have a ground location or idea which ground or fuse could be bad?
Cant read wiring diagram.
All dash lights are out even speedo and guages.
also tailights are out...coincidence?
thanks
What year? FJ40? Happen all of a sudden? Did they ever work? Most likely a bad ground? Recent work done? Details............
its a 75, and it was all of a sudden, however when i was wheelin in the snow my wipers quit (weeks ago) and started again later after I restarted it. Now everything works except the fore mentioned.
Jeremy, I'd be almost willing to bet that you have several bad grounds... I would start by running a .22 cal bore brush through your fuse sockets to make sure that you are having good contact there, maybe pull your gauge cluster and make sure that the screws are cleaned up and paint scratched away from where the little tabs on it sit, and then just do your self a favor and take a wire brush on a drill and sarting at the tail lights, clean up every mounting screw and ground that you can find. It'll take a few hours but it will be well worth it in the long run.
HTH! Also, if you need some tools or anything, I think that I'll be working on my cruiser for a good part of the weekend and you would be welcome to what I've got!
Thanks Coe, I probably do have some issues Ill take your advice and start with the dirty work. Me and a buddy did that to the engine bay a few weeks ago cleaning everything up with new connectors and wires. I was dreading getting under the dash and hoped someone had a specific ground location they knew of for guages and lights, as im not an electrician to say the least.
unfortunately, I work most weekends so I cant take you up on your offer. Im off today and tomorrow so ill have some time to start. on that before i hit the muffler shop for a new exhaust.
on my '76 the head light switch is the culprit. the dash lights will only work if the knob is turned all the way to one direction (the left I think). they can just go out on me when driving but I just hit the knob and they come back. I'd definitely check grounds and clean the fuse block as they are common causes of electrical issues but the switch is part of it too.
Eric
Jeremy, Every contact (Pos or Neg) in your forty is a posible weak link, I use a contact cleaner by Caig Deoxit D5 works great. You just need to go over every contact and spray it on. BTW the 22 cal bore brush is a very handy tool to keep in the tool bag just remember to disconnect the battery cables when working on the Truck. just another note check to see if your fuseable link is good and not replaced by a normal piece of wire. I have read a few horor storys here on mud because of a bad fuseable link not working like it should and frying the loom. like on my truck by the PO or PPO.
good luck its time consuming but well worth it.
vfrer,
Yea my switch was the same way but now I dont get anything no matter wich way i turn it, but there is an audible click.
Get a hold of Drew at Kickass Stuff For Your 40-Series. I just ordered a new dash light system to replace the OEM on my 77 with his LED system, it's only $200. Then, I intend to replace every switch possible with new OEM or something else that is out of the box new. I really don't want to go through the sudden electrical problems along a dirt road a long way from no where.
vfrer,
Hey man!
My switch did that when I bought my 40, so I took apart the switch itself, and found that one of the coils on the rheostat inside was broken. I VERY CAREFULLY soldered it to the next loop on the rheostat, put the switch back together, and VOILA had my switch dimming the way it should again.:idea:
As far as a ground for the instrument cluster, I think that the only ground for it is where it mounts in the dash. Pretty easy to clean it up.
I would also take a test light and make sure that you are getting power to both side of the fuses. If you are, that eliminates that possibility very quickly. I would then check to see if you have power going to the light switch. This is where a wiring diagram would come in handy if you have one- just to see which wire is providing juice. If you don't, PM me and I can help you out with that.
HTH!
thanks Coe, Ill check that out. Theres a diagram in my repair manual, Ive loked at it but was like reading french to me. 5 years of college and I never got into anything like that. (also type like I dont know english)lol
So I just glanced at my wiring diagram...
  • Looks like a red wire powers the headlemp switch
  • A red w/black tracer wire runs to the cluster to power the lamps there
  • All ground wires on a cruiser that has not had a PO mess with the wiring, will be white with a black tracer.
If you don't have a test light, I would highly recommend getting one: Napa has real nice ones with replaceable bulbs and a stout clamp, but I also have one from wal-mart I bought in an emergency and has served me well many years.
If I were you, I think that I would pull my cluster and make sure that I am getting juice to the red/black wire mentioned above, and then if you do, make sure the cluster is grounded well. (on the bottom where the cluster sit in the hole in the dash and also maybe take a wire brush to the mounting screws.)
I am no automotive electrician and since the 'Cruiser is a toy and therfore isn't the prioroty for my vehicle funds, I have not payed anyone to figure it out for me. But I have been able to successfully troubleshoot all of my electrical gremlins with just a passion for 'Cruisers, a wiring diagram, and some good threads on here.
Using search function to research similar issue as OP. Dash lights and running lights working perfect one day, and not the next. Fuses look good. Any thoughts?
Edit Update: Well, disregard, evidently laying hands on wires underneath the dash does cure some things.
