Dash lights almost gone.....
North GA
So my shifter, seat heater, and just about all of my AC lights in my dash are just about toast. I've done a lot of reading but was wondering if someone can just give me a simple replacement number for these lights??
I don't want LED.......just want simple replacements.
Thanks
Type A 83120-60020
Type B 90010-06029
Type C 90076-04003
If my old notes are correct, the Toyota PN for the “Type B” bulb is 90010-06029
From memory most of the replaceable bulbs behind the center stack (HVAC, diff lock, hazard, antenna, row of 4 buttons across the bottom) were a “Type B” (or T4 LED).
The clock lighting was 2 “T5” size LEDs (I don't remember the Toyota "type").
The switches like the seat heaters were “T3” size LED. (I don't remember the Toyota "type").
The shifter(on the console) and key illumination were #74 bulbs if I remember correctly (I don't remember the Toyota "type").
After doing a little pricing and playing with the bulbs (and their green condoms), I gave up and went the SuperBright LED route (regular output in green) as it seemed simpler and cheaper.
Our end result:
AC Illumination
Highly recommend going LED, less power consumption and they will likely never burn out in your ownership.
Awesome.....I think I'm just going to place an identical order from SuperBrightLED.
Thanks!
If you do decide to go the SuperBright LED route, these two threads were very helpful:
LED instrument panel/gauge cluster
AC Illumination
On my son's vehicle, we weren't trying to do any of the fancy color changes, we just wanted some sort of lighting (as most of the factory bulbs were burnt out) preferably in factory green (or close to it).
These guys are great... VLEDS I used a combination of their LED's and PFran's 100 Kit. Couldn't be happier!
