Daschel gets refreshed
Louisburg Kansas
Hello! I have been posting in a new member introduction post but thought I would shift the conversation over to a new thread as the FJ40 turns into a project. Daschel is a recent purchase and has been sitting outside for years. I’m not planning on a full restoration, but would like to make it mechanically safe and running well.
I was hoping to keep the drum brakes but when searching for parts I can see why everyone seems to go for disc brakes. Daschel is an early 1970, so it has a single master, 9mm fittings, etc. I can’t find the rubber flexible brake hoses, and need to upgrade the master to a dual circuit so I guess disc all around makes sense financially and for performance.
I'm documenting the brake conversion on my Youtube site Machinitect.
Excellent video! I hope you will continue to video more Cruiser progress.
I appreciate your comment. Yes! I’m planning on a video for most of the major stuff. They are fun to make, plus it will be easier to figure out how to put everything back together. Please subscribe when you have a chance. More subscribers equals more pressure to get down to the shop often.
Before installing the new brake lines, I needed to clean up some of the rust on the frame for chassis paint. The 40 has no wheels or hubs right now, so I just wrapped it in plastic, crawled under it, and blasted it. I thought the blasting dust would trash my shop but the cleanup really wasn’t bad at all and the coal slag media stayed contained. This video shows removing the rear wheel bearings also.
To make some of the body panels, I have wanted a bead roller for years. It’s time to finally make one. I’m lucky to have a close friend with a CNC plasma table, and we took a video of that process yesterday.
Hope you all enjoy these videos. I know they are a lot of fun to make.
Nice job on the videos. Keep it up. Definitely helps dummies like me. Sweet idea on the blast room!
Appreciate it! I was pretty worried about blasting inside, thinking it would just trash the place. I also haven’t ever blasted anything while it is still on the vehicle, but to me it’s worth the risk because I can’t stand running a cup brush. I masked off most of the openings, but will still rebuild the carb, clean the intake, and replace more seals and bearings that may have been compromised with grit.
I made some progress this weekend. The first coat of eastwood chassis paint is on the frame, and I found a treadmill motor to use for the bead roller. The bead roller needs wrapped up soon so I can make the gas tank under-pan piece.
Enjoy.
Making some more progress on bits for the brakes. I made the dual master bracket out of a 3/4” thick piece of scrap steel. This video also shows the solutions for a location for the wilwood brake proportioning valve for the rear discs and a little bracket for the rear diff brass brake 3 way tee.
Neil
