dana 44 help
tap on outer side of the axel shaft they should drop out!
A dana 44 should'nt have C clips. Axles are held in by the outer bearing and retainer on the end of the axle tubes, behind the brake shoes.
my dana 44 has C clips... i guess mine must be custom! :flipoff2: Take out the spider gears first, it should be pretty easy! Then tap the axel shaft and the c clip should pop right out and fall in the bottom of your housing
Sorry for the mis information. I didn't realize Isuzu used a C Clip dana 44.
Custom? Sounds like it needs to be customized.
did you get this thing apart 68... im interested to see how you did it!
