Damaged spindle - how?
Salt Lake City
Just talked with some friends that are down in Moab this weekend. They ran Behind the Rocks today. One of the trucks had a decent shimmy when back on the road. The pulled the front wheel and the whole spindle came off. The hub nuts had stripped and they said the spindle tube had deformed slightly. Also, the brake pads were almost gone, apparently from the rotor sitting at an odd angle.
Now, I understand that if you overtightened the hub you can cook the bearings and trash the spindle, but I'm having a hard time figuring out how they'd do this damage. Maybe not trail damage but something from before that just manifest itself?
:eek:
That doesn't make sense. If you removed the lugnuts holding the wheel on, then the whole spindle simply fell off - there's no way the truck would have even been sitting still and supported by the spindle, much less driving around with a shimmy.
Sounds to me like someone drove the truck TO Moab with the issue - that much heat would not be generated on the trail, but would be on the highway.
DougM
Agree. Having no further info, I'd guess the spindle nuts were stripped, but holding the spindle on fine. The only time you'll find they're stripped is when you have to disassemble the bolts and then it's a pain to take it apart to get the spindle off. I'd bet that's what the 'stripped' part was.
I'd guess the 'distorted' part was the wheel bearings melted onto the spindle and ground into the bottom of it. Sounds like wheel bearing issue started the whole mess. Bummer. They need any help down there?
DougM
Not sure what they'll do. I pretty sure there's not a spindle in stock at any of the dealerships here in SLC, Dan would probably be the closest. Worst case one of the guys in the club has an axle from a 93 that someone could take the whole knuckle off of and drive down to them.
What year is the stranded truck, 'cause there's some variation in drive plates that will cause them headaches. I believe the 93 has the thin drive plate and later models (95+?) have thicker drive plates and longer stub axles. One of the very few mechanical variations over the 80s life.
DougM
I have two spindles in stock.
