Damaged Distributor Wires
Indiana
I’ve got two wires running to my distributor harness to repair (the red and white ones in the attached pic). The wires don’t appear to be broken, just missing insulation. Looks like they were possibly pinched by the shop that did a short block replacement for me. I’ve ordered the harness and pigtails from Toyota. I found a copy of the Electrical Manual (97 LX450) and it indicates these 4 wires are shielded. On mine, where 2 of the wires are missing insulation it looks like it’s just regular wire and can be simply crimped. Does anybody know if these wires are shielded in the sense that there are two layers of insulation with wire in the inner part and a shield just inside the outer insulation, or is Mr T. referring to the grey plastic wrap around all 4 wires as the “shield”? I’ve got one opinion from an expert on Cruisers that he thinks it’s just regular wire. Wondering if anyone on here has made the repair successfully with just a standard crimp? I just don’t want to botch the repair and cause more issues. Also, I’m hoping this is the cause of my multiple cylinder misfire, rough idle and ECU continually defaulting to cold conditions since these wires apparently signal to the ECU. Thanks in advance!
Regular automotive wire. That connector is receiving the pickup signal from the two coils (inside the distributor) that sense the rotor position. They provide critical sense information for the ECU to fire spark at the correct time.
cheers,
george.
