sl33py said:sweet rig! Let us know how much the susp. settles. Also, who has the dakars, and how do they rate against the regular OME? Pretty big $ diff - would be nice to save a bit. Thanks!
FJKai said:I measured the distance between the center of the hub and the bottom of the fender and it's about 22.5 inches.
Kief said:82 soa 60: Are you 4WD-able yet?Soon Grasshopper very soon....
Kief said:Hey, lookin' like we have the makins of a 60's run. Looks Good Kai.
82 soa 60: Are you 4WD-able yet? Did you cut Kai a fat deal on your 33's and so this means 35's?
So when are we goin' and where?
RredFJ40 said:I'd come over for sixty run if I was invitedIt'd be cool to meet some listers that are fairly close.
Tinker said:This is directed to Dr. Dearborn as much as to FJKai's krew:
- Is the Dakar combo "engineered" - i.e. shock length matched to spring travel & shackle length?
- Does it use the stock bump stops?
- Did not the 1-1/2" longer shackles result in 3/4" lift over stock Dakar?
- What about U-bolt flip kits (MAF, for example)? - do they interfere with the designed shock travel?
Trying to lay out my suspension upgrade & like everything I saw in this thread.
