D40 Carb Questions
Chattavegas, TN
Okay,
Could not find a SD40 for my '67 FJ40 with the original F to replace the carter installed by a PO.
(Could not afford a professionally rebuilt SD40 either thanks to recent economic conditions)
I did find a D40 which looks to be in good condition except it is missing the step-up rod. I have found the correct kit, for which I will add the numbers found on the attachment for legacy sake. (Keyster K11-353A, Original Kit# 04211-60110/60114, Carb No. 21100-60150)
?#1)The kit appears to have a step-up rod included but how in the world does it attach. The arm has two empty holes but I don't see any scarring to indicate anything was every attached.
?#2)Also, the brass component next to the main jet is seized.
Is appears to have a spring and E-Clip installed. Is it supposed to move freely?
?#3)From what I have read, the D40 was installed mid year in '67 so it should replace it fine. (True?)
As always, thank you very much for the time and knowledge.
Brog
fish hook looking deal and the tiny spring go onto the step up rod. The top piece of the carb holds it down into the seat. the tiny spring is used to hold the needle straight so it inserts the hole correctly. clear as mud right?
Okay, found a schematic from another post, thanks IDAVE, and it appears that there should be a pin on the bracket which the spring and "hook" mount. A picture would be great if anyone has one....
Hi everyone!
I have the exact same problem!!!
I just bought a D40 to replace my aftermarket Carter carb. I started tearing it apart to rebuild, and lo and behold... there was no step up rod (The fish-hook looking part).
The rebuild kit has a replacement step up rod, but no clevis to attach to the plunger "bracket".
Were these made to use without a step up rod? Anyone know where I could find the tiny clevis to attach the rod?
Here's a photo.
Hi, just another bump.
I was planning on finding a small clevis pin or screw to attach the rod.
However, it seems as if it had never had one in the first place. Was it supposed to NOT have one? Any insight or help would be appreciated.
I put everything back together but there is no way the step up rod would be able to work with the parts. So I left it out.
Got it back on the 40, and its running super smooth at high idle, but, can't get it to run smooth under 900 RPM. Been screwing around with the mixture and throttle screws for about 2 hours.
Timing is "dead" on, I don't detect any vaccum leaks, I tested the intake with a vaccum gauge, and its reading 18 mm of hg, and is not fluctuating.
When I had my old Carter on, it ran smooth as butter (but leaked gas everywhere). So I know its a carb issue.
Anything I can check would be greatly appreciated.
Hey I would appreciate that.
I had actually been searching for the last 2 days, and haven't found anything. Everything shows there is a step-up rod, but, I couldn't get it to work in my 1968 stamped D-40!
Update: I got the truck running smooth as silk @ 500 rpm. Turns out that I had some crud in the gas tank and the fuel filter was clogged. Funny that it happened the same day I changed my carb? :confused:
I also cut off the idle solenoid rod just in case it was causing problems.
my d-40 small sight glass is the same as what you have posted. There is no metering rod on the plunger assembly. I did have this carb on my rig at one time and it ran really nice. I'll look and see if I have any parts books with the d-40.
well, my parts book has a big glass d-40 in it and it shows the step up rod connected to it. maybe mark or jim could tell us why it would not need it.
I can post a pic of how the rod attaches in an early sd-40 carb, the lever is a different style. in the hole goes a brass fitting then a tiny spring goes though it holding the step up rod.
Thanks so much for the replies.
I feel better now, knowing that it did not need the step up rod. I just thought it was odd since I had gone through the FSM, and Haynes, SOR, Marks offroad, etc... all showing the single barrel carbs needing a step up rod!
Anyways, the engine is running great. I am so stoked to have it purring like a kitten again!
Yes, the step up needle disapeared sometime in 66 or 67.
If the carb has a gianormous main jet that the rod can be dropped into, then it gets a rod.
If the main jet is a reasonable size, and the rod won't fit, then no rod is used.
IOW, it disappeared the same time the power valve appeared. Not a coincidence.
Best
Mark A.
That makes sense. Sonny at FJParts had two kits which could overlap for my non-USA 1970 model. The fishhook screw and spring were the only two parts "different." However, the main jets provided in each kit are way different. Without the fishhook is a 150, with the fishhook is a 270.
With the carburetor apart I noted that while the arm for the step up rod is still in place, there was nothing connected to it and the jet was of the smaller size. In my case a 108, presumably for altitude (8,440 ft) instead of the 150 that came in the kit NOT for the step up rod (270 in that kit). I also noted that the incorrectly set float was due to the height of the float seat assembly being 6mm taller than the one in the kit. This height difference caused the float to hit the body of the seat assembly preventing the raised setting of .230. So I checked carefully the relationship of the tab to the float needle piston to make sure it was hitting flat and square and my sticking float problem appears to have gone away. Test drove the vehicle this morning and it is smooth. Just a touch of the key and it is running.
