Cylinder squirt....
My 80' fj needed new cylinders on the rear drums. Two out of the four were seized up, so I just replaced all of them. \
New clylinders don't indicate anything....L/R upper lower etc. After installing new cylinders and bleeding the hydraulics, one cylinder literally squirts fluid! Maybe its in the wrong location and needs switched with one of the other cylinders??? But where? And how to do I differentiate between cylinders. :confused:
The cylinders shouldn't leak in any location. A leaky cylinder is defective. If it is leaking out of the hydraulic line, the installation is defective.
The cylinders are located so that when you adjust them, turning the adjusting tool toward the axle tube lengthens the adjuster screw.
I agree the squirt ain't normal. Hydaulic lines are not leaking, its the actual cylinder around the seal. Maybe all it needs is an adjustment, I will try this. I just want to verify that the new cylinders are in the right location. There are subtle differences between each cylinder but none of them appear to be marked. Any advice or links that might provide info??
Nope. It's NFG. Parts store, not Toyota, right?
If it's leaking around the seal and the piston is not out way too far then it's likely to be defective. I buy toyota stuff only but I've read that Napa sells a very good product sometimes they are in fact TEQ parts from a a vendor with the TEQ ground off. don't hold me to that though, I paiad around 45-50 bucks each from the dealer, make sure they give you a TLCA discount. If your not a member join, was the best 20 bucks I've spent.
