cylinder compression
california
I have a 97 LC w/CEL , code is p0306 .Already know what the possible items are with this code . Checked the compression on all 6 :
1,6 125-128 psi ( is this too low)
3,4,5 165-170 psi
appreciate any thoughts good or bad
Marc
Too much variation between cyli ders.
Do a wet test also.
Also.send off an oil sample to Blackstone.
1 and 6 are not only way different than the others but about 20-25 psi lower than they should be even if they were all same.
You could perform a compression leak down test and determine where you are losing the compression in those cylinders.
I had low compression like that on #1 cylinder only. Turned out to be one slightly toasty valve. Machine shop cleaned up the valves an installed new seals. Old head gasket was in great shape but replaced it while we were there.
