CX Racing header O2 sensor
I have a '94 FZJ80 and it is in need of a new exhaust . I have a CX Racing header with an up turned 3" pipe to continue the factory routing of the exhaust. It only has one flanged O2 sensor connection downstream of the split header (common pipe) and the Cruiser runs two O2 sensors . I'm not going to run catalytic converters , so , is the best thing just to weld in another flanged O2 connection next to the one that is on the CX common pipe ? It sounds like tricking the reading of the second O2 sensor by soldering in a resistor to replicate a good reading is not a great idea . Has anyone dealt with this issue ?
You can install them directly into the exhaust manifolds where the emissions thingy is. Can't remember the name of it off-hand lol.
Well, that's my first derp of the day lol. Yeah, you can get o2 bungs that will fit on amazon. The o2 sensors on the 93-94's don't check for a cat. They just read the exhaust and report it to the cpu.
IIRC, the OBD1 rigs are fueled as two 3 cylinder motors, bank 1 is 1-2-3, bank 2 is 4-5-6. So to fuel properly, the O2 sensors need to be properly placed in the banks, in or slightly downstream from the collectors.
Never knew that about the 1,2,3 bank and 4,5,6 bank that @Tools R Us describes, pretty interesting. That kind of moots my point but for info, on my 97 with cx header and no cats, the resistor mod to o2 sensor #2 took care of CEL issues.
My son is a automotive tech and said that you should not just fool the O2 sensor or you could burn a piston . I'm surprised that this product does not cone with the ability to install both O2 sensors . I think it sounds best to ideally weld in two sensor connections onto each of the tubes that lead to the common tube of the header . I guess that if there were no mods in life things would be too easy !
On most cars (not sure if the 80 is an exception) the second O2 sensor is only to check if the cat is working right, nothing more. The primary is the one that's important.
The OBD2 motors are upstream (motor tuning) downstream (only checks cat efficiency, emissions compliance) so different deal.
Well , I'm very sad to say that this expensive "nice looking " header and Y pipe set up has failed me dearly !
I did a complete custom exhaust from mandrel bent tubes last summer and ran it all winter . I only run the 80 in the winter because I go topless in the 40 all summer . When I got the 80 ready this fall ( yes one winter ...maybe 3000km) and drove it four or five times it started to sound loud like a leak somewhere . Upon further poking around I found that both the flexible connectors at the frame were rotten completely . The braiding was shot and the corrugated pipe underneath was broken . It looks like the road dirt packed up in behind the braiding an it rotted the "SS" . Maybe the pretty looking braided pieces were a facade . Actually the SS piping within the wheel well looks worse than the aluminized pipe on the rest of the exhaust !
The real sad part is that the two bungs I had to TIG onto the dual pipes are what is what I should now replace . They were a !*#^! to weld on too ! This might be a good product for California , but , not for Canada :cry:
CX Racing is all cheap chinese junk. The stainless is such low quality I'm surprised it qualifies as stainless. Running their stuff on a test rig and it was just a few months before it was rusting. And yeah it looks good for sure, but...
I tried to band aid the rotten flex couplings and just could not quite get anything to work out . I cut them out and was going to put band clamps over the gaps where they were to get me through the winter . They were flared out to an oddball OD and nothing would fit .
Is there any reason to have those flex couplings in those pipes ? An exhaust guy told me that with an inline 6 they should not be required . He said that it was the transverse mounted engines that you needed flex couplings . I don't recall that the stock set up had any flex couplings in the system .
There really is only one way to fix this and it will be to weld new 2-1/2" pipe back in place of the flex joints . I guess the saying " chrome don't get you home " is very true in this case .
Wonder if those CX Racing people can sleep at night knowing they are ripping off the world with total crap ! Pass the word on cause I'd hate to see anyone else waste their hard earned money on this chrome plated turd :poop:
