CV Re-boot Question
Philadelphia
Pardon my ignorance as a former Jeep owner but I have a question about CV joints :)
In preparation of buying a gx470 ive been doing a ton of research and one of the first preventative maintenance jobs ill be doing is a CV reboot since it will likely be 12 years old and 120k-ish miles. Id rather spend a small amount on a reboot and have good CVs for the foreseeable future instead of playing roulette with old drying rubber and having to check constantly.
ANYWAY
In looking through the interwebs its is always mentioned to clean them THOROUGHLY, which makes sense but then thinking critically, why? If the grease was un-tainted and my primary focus was the boots, why wouldnt a 95% clean with a lint free shop cloth be perfectly acceptable before adding the new grease and boots? What if the OEM boot stayed together for 200k miles, would the recommendation still be to dissemble them because of grease breakdown failure?
The simple answer is "You already have them off and apart, just do it right" but im hoping there is a better reason then just "because"
Grease does age. Personally, if you have 120k on a CV and plan to see any dirt, I would get OEM new or the remans from CVJ Axles - CV Axles & Steering Racks for all your needs and use your stock ones (rebooted) as a spares pool. If you are just a DD with little offroad, then just reboot, clean as much as you can, and regrease. A little left won't hurt a thing.
Dan is right. Get them as clean as you can. Just need a roll of rags. The dealers dont use a parts washer so why should you.
On that note, I'm re-booting my stock axle and for the life of me, I can't get the shaft out of the outer CV. Is there some special trick? Ive tried the pipe trick and using a brass drift/hammer on the cage with the shaft in a vise...
This is all pretty much what I thought.
I have definitely passed my hard trail days. Ive gone the overbuilt route, rarely used it, then took a financial bath selling it. This will be 90% mall crawler and 10% beach vehicle. Plans are 2" lift and custom roof rack with retractable awning and MAYBE a roof top tent if i can justify the expense :)
My son is 3 and i would love to turn this into a camping vehicle but i would need the stars to align so Im assuming no.
I'm the same way, Snowy. I came from a built 80 series with lockers and I think my crawling days are over. Now I'm more adventure/overland/camping. 33's, 2 or 3 inch lift and a rooftop tent is as far as I'm planning on going with this rig.
I went down the same path (I had an armored locked lifted 80 on 35's). I realized that I didn't do anything remotely near the capabilities of that truck and I'd be much better off with something suited for what I actually do (i.e. forest service roads, medium-difficulty trails and camping).
haha im even planning on keeping the running boards on. My son loves my dads stock Xterra and is at the age now where he wants to climb into his own car seat.
Unrelated, after Offroading i got into Karting and if anyone has the opportunity near you I HIGHLY recommend it. I tow to the track on a HF folding trailer behind an Acura TSX wagon and there is almost no fear of stuffing the vehicle like offroading since you can just pick it up and bring it home if anything goes REALLY wrong.
That'd probably be a fair amount cheaper than the racing I do (LeMons), but...I probably shouldn't find yet another hobby. :P
