Hey Dudes,
If you discovered you have a torn CV Axle Boot(s) (most likely after you installed a suspension lift) this video will show you how to reboot your OEM Axles. Lots of guys decide to just swap out their OEM axles for some aftermarket ones they buy at an auto parts store, but in my opinion, that is a bad decision. OEM axles are superior to anything aftermarket unless maybe you're willing pay an arm, a leg and maybe even your left nut for a set of axles from RCV. Also, it would be stupid to buy a new OEM axle when you can simply reboot it and save a bunch of money,
If you've been watching some of our latest content, you might have seen our Front Differential Axle Seal Replacement video. If so, that video has a lot of the same footage as this video because we were filming both videos along with 2 others all at the same time. So, if you have watched that diff axle seal video, I would suggest skipping to play time 14:45 after we've removed the axle and we're getting ready to start documenting the reboot procedure.
In this video, we do install aftermarket silicone boots made by CVJ. After a suspension lift, your CV axles will be at a more extreme angle which can cause the boot ribs to rub against each other. That rubbing generates friction and the boot can tear. The CVJ extended inner silicone boot helps reduce the chance of you prematurely tearing the inner boot.
I hope you guys enjoy the video. Happy Wrenching!
timmythetoolman.com
CV Axle Reboot / Replacement (Toyota 100 Series Land Cruiser & Lexus LX470) - Timmy the Toolman
CV Axle Reboot / Replacement (Toyota 100 Series Land Cruiser & Lexus LX470). Watch this video from Timmy the Toolman and explore related DIY Toyota and Lexus
timmythetoolman.com
