Cutting the Fat!
My buddy has a stock 74 cruiser I'm not sure if it's the f or 2f it's a 03/74 and it has all of the stock smog crap (spaghetti) and a nice vacuume leak somewhere in the mix what I want to know is with his stock carb can he safely remove all of the smog stuff...the only place I could see it being a problem is with the stock carb...he'd prefere to keep the stock carb if possible
Thanks
Brandon
I have a 74 (its an F) with the stock carb and no emissions stuff.
However, my carb has been reworkd by Jim Chenowith, which I would highly recommend. (just search).
Does he still have the airpump, air rail etc?
I would highly recommend porting his carb for vac advance and springing for a vacuum advance distributor. Several threads on this recently.
It's an F, and the PO took care of the emission controls for me! :flipoff2: If you disconnec everything, just remember how to put it back together. You should be fine, as the EC stuff back then is pretty simple and primitive, so you shouldn't have too much trouble.
Not all of that stuff is there for "smog control".
Some of it is early electronic engine control to maximize fuel economy and performance simultaneously. Just removing all of it will often make it run worse if it is functioning properly now. The carb and distributor are designed to work with the electronic engine control. It may have worse performance and economy and have bad driving properties, like pinging and detonation or popping in the exhaust manifold during deceleration.
The simple and effective way to eliminate the smog control is to disable the EGR valve by plugging its vacuum line to make sure it stays shut. If you want to save another .5 hp, you caan remove the vanes of the air pump and its associated plumbing.
