TheBigBoy said:
Its purely personal choice to chop or not. But here. You would be hard put ever selling it with chopped out flares.
Primary reason for a not-to-chop position?
I'd rather not, if it's unnecessary.
As for resale value, my wife can worry about when I'm dead, I could care less.
TheBigBoy said:
Not knocking 37's. And if your happy with the rolling diametre for the small bumps, thats fine. But 35's on 15" wheels running 20psi, will have the same footprint as 37's on 17" wheels running 15psi. Due to the sidewall, unless ofcourse its bias or 8 ply etc.
In my case, the 37s are for clearance at the diff. I've ran 35s (35x12.5x17 BFG KM2s on Trail Ready's which measure ~34" at the crown) on the FJC, which by all appearances has more ground clearance at the rear differential in stock form (3/4" at least) and still drag.
37" BFG KM2s on the same wheel affords at least another inch, but still a far cry from a true 37".
Issue with 15" wheels, besides clearance at caliper (I'm betting a 15" TR, or other, in a 3.5" BS and a little grinding would clear) is tire availability.
37s in a 15" flavor are limited to Pitbull Rockers and Toyo's. The first is great in the rocks, but at the expense of longevity, and the latter is heavy.
TheBigBoy said:
A tuned suspension with 33's or 35's will go more places than a small lift and 37's. But yes, some $$ need to be spent to correct caster and bring the numbers down on the anti sqaut and anti roll axis.
To eliminate straying too far from the thread topic, but in line with discussions elsewhere, in using the same formula, concept, design, a 6" lift should clearance 37s, without cutting fenders, and still afford the same travel, correct?
I'm not opposed to cutting, but considering the 162 holes I have to weld, the energy could be allocated elsewhere.
