Build cuttin up the lx
yeah thanks i saw that video before. You put it in perspective now.
here's the difference, for those interested, between 5psi and 20psi in the rear tires (to the bottom of a 14bolt) i usually run 7-8psi in the front to match the 5psi in the rear.
(11.5" at 5psi and 12.75" at 20psi)
Thank you.
Stupid question that may have already been covered: what rear axle is that? 14 bolt? Don't see too many axle swaps on here.
yes. i ran it a lot just after the swap (before the bead locks and drive flanges) and it drove almost as good as stock. other than not having sway bars, you would never know that it had tons. with the transfer case flange and the pinion flange at the same angle (like this / /) the u joints are fine. i've driven it at 75 mph and it was as smooth as ever.
Thanks!
Welcome back.
You can weld it back on..
Did you make a new top for it yet?
not yet
Welcome back.
thanks! it has been a while.
i could, just tired of dealing with the windshield frame and keeping other glass.
its getting a full cage, lexan windshield, and aluminum roof.
Can't wait to see the finished product!
Looks good so far.
Working out side? I thought you had a killer shop to work in?
Awesome
You don't mess around!I like it.Most people would cringe at the thought of chopping the top off of what was once a $40,000+ suv. Can't wait to see it finished
