Cut 'n turn discussion.
cruiserdan
SupportingVendor Emeritus
Moderator
Mod Emeritus
Prepping for Canyonlands
All the recent threads about suspension and caster have me thinking (a danger I know, but it happens....:flipoff2: )
Cut and turn has been mentioned a couple times but not really discussed. I know the leaf spring guys do it all the time with good results. I am somwhat concerned about doing it to a high pinion 80 front because I suspect it could oil-starve the outer pinion bearing.
Discuss......
On how much lift? I am presuming you are bringing the pinion up after turning the knuckles?
I went to a high pinion rear on my old XJ for driveline clearance using a Currie HP 9", which is a Ford 9" with a custom third member using Ford 8.8 gears out of a front IFS Exploder. It had special oil routing for exactly the reason you describe.
But this was also on 8" of lift with a 14 degree pinion angle and driveshaft. I think there are recommended specs on max pinion angle. I imagine these could vary by axle depending on the design of oil flow, but I seem to remember hearing something like anything over 11 degrees was a potential problem. Don't quote that, though...it's been a long time...
On a relatively small lift (up to 4" at least) I don't think you would have an issue. The 80 doesn't need a ton of angle due to the long wheelbase and driveshafts.
Nay
Discuss......
Unless your going for a huge lift, I don't see where it would be a problem on the 80. The pinion points up at an angle stock and is designed to operate that way even including an oil storage ring, Most of the time, even with big lifts, the angle your looking for is around 0 pinion degrees to the shaft for a CV, probably not much angle difference from the stock broken back design?
Isn't there an oil slinger on the pinion? Even if not couldn't you just slightly overfill the diff through the breather to keep the bearings lubricated? I am surprised that more people have not cut and turn the knuckles. That way you do not need to compromise between pinion angle and caster.
The bigger problem you would face is, by cutting the knuckles and turning for more caster the tie rod will rotate down, interfering with the arms?
At some point, yes.
Dan, Jeff Jones 80 series has been cut and turned for several years now with no ill effects. It has a bunch of miles on it and is still going strong. I did it on my FJ62 to get 5 degrees positive caster and it worked fine. On the 45, I could use at least 4 more degrees even with Christos arms, but I am not ready to cut and turn yet. A new set of arms is in the works with more available caster correction so I will wait for them.
G
landtank said:
from my work, cut and turn will go to about 8* safely, after that you might get the tierod to start rubbing the arms.
But 8* should cover whatever you need to get the caster correct for a lift in the 4" range.
I'm gathering that the tierod contact is an issue at some point when trying to get maximum castor. I know so by first hand experience. I actually had to grind my arms a tad because i have slee's plates on along with my medium lift since my castor with the bushings in was zero degrees.
So i would think this would be a good example of putting the arms on top of the axle? I know i had heard from a few aussie fellers that you would need about 6 inches of lift to comfortably do that without the arms hitting. I wonder if you could put them on top with 4 inches of lift without worry of the arms hitting the frame or anything? With the arms on top, no matter how much castor you introduce, hitting the tie rod on the arms sholdn't be a problem.
Has anyone tried cutting the control arm brackets off the front axle and "turning" them?
-B-
Dan,
I would also think the oil slinger for the high pinion would help the oil issue. For all the cut-n-turns I have done on 40/55 front ends, I just add a high fill to the face of the housing. I also move the breather line to the top side of the axel housing by the dif. With the breather moved I then cap off the stock one. This allows for over filling the housing a bit with less oil creeping up the breather line. The other advantage of moving the breather line is I go to at least 3/8” breather line and opening in the housing to increase the air flow. This has helped with ARB’s to reduce suck back on the inner oil seals.
I will let you know how it works on mine as I swap over to the new link system and coil overs. The rear tie rod is of concern to me.
Texas dudes: Didn’t Butch Baker (Wiseone) cut'in turn his daughters 80 front end a few years ago?
Mark
landtank said:
you can't use Slee's plates as a guage when talking about a cut and turn senario. This is because Slee's plates don't rotate the knuckles on their axis. It's more of a hinge move off of the rear bushing which will create a contact situation quicker that a cut and turn.
Wrong answer!:D Any front bushing only corrections slightly move the arms away from the axle center line, adding slightly to the tie rod clearance, at the expense of ground clearance under the arms.
-B-
That would correct caster but the main reason for a cut and turn is caster AND pinion angle.
you lost me, but the path of the tierod is different when doing a cut and turn as it is centered around the axle's center and not the rear bushing. You will be able to get more correction from the cut and turn before contact because of this.
Mark
That was done at Sunray Engineering Mark. Thats the same truck I was talking about belonging to Jeff Jones. He was the guy riding with me on Behind the rocks.
older thread back to top. FWIW a lot of mini truck guys run 80 diffs in the front with cut and turns and only report issued when running them in the rear, not in the front. I don't think the lack of oil on the pinion would be too bad, even with increased pinion angle. The big benefit I see from a cut and turn is caster though, not increased pinion height. If you rotate your pinion too much, you have to move everything else (80 series coil spring pads and assorted junk to have it match the adjustment...
Back from the dead! I don't think that tie-rod interference would be any worse than running castor plates... That being said, I don't think that oil starvation would be any worse than running your lift without castor correction (the way mine is running currently). To be honest, I'm seriously considering this as my axles are torn apart currently... I could have it out with 7 bolts... Hmmm...
