Custom PS high pressure hose
Louisville, KY
There are 0 vendors in my city who can make/will make a PS hose that will hook up my fj60 pump to my mini truck box. I know that some of you have stated getting custom hoses made, can you turn me onto the vendor?
As well, what types of fitting-size and type are the mini truck and fj60 pump fittings?
Thanks.
I've had most of my custom hoses made at the local NAPA stores. You might need to find one in a more rural area that also serves the farmers and construction companies. It also helps to take in a fitting from each box so they can match it up easier instead of needing to look up a hose from each then digging out fittings then making a hose. You gotta make it as easy as possible IMHO to get what you need...
HTH,
Nick Jennings
I would be surprised if you couldn't find an off the shelf hose that would work. I used a hose from a 2wd 85 Toyota truck, for example. Model the length and shape of the hose with a coat hanger and bring the fittings in to your local parts house and ask for a hose that will work. If the parts guy isn't busy and is in a good mood he will let you look through his stock.
The fittings are metric flared tube fittings. Early boxes have a smaller nut than later ones on one of the lines.
Some farm/tractor shops do this work. Check for a business that does hydraulic hoses for industrial applications. There is usually one guy in a large metro that does this work. Ask/Call hydraulic repair shops as they use the same equipment for manufacture and normally have the fittings.
The point is that Toyota didn't make hydraulic fittings specific for just the cruiser, they used the same fittings (and in many cases, the same pump) on all the hydraulic lines for their entire line of vehicles. I haven't tested all the possible combinations, but I do know that many of the fittings are interchangeable on different makes/models/years.
yes. But tell me again what PS box you are using again?
I know you can get a aftermarket hose for a 60.
I wish I could recall what I used.......but I can't but I know I posted it before I forgot ;)
Jukelemon said:
Pimp:
OK, now I understand your first comment. Mini fittings on the fj40 new case. Got you right?
Juke
The NAPA website sometimes has info along with the PNs - might be somewhat useful. Either napa.com or napaonline.com I think. At the very least, I have found stuff there that my local NAPA guys either can't find or are too lazy to look for. :rolleyes:
-Tyler
OK. Here is what I found and here is what I am going to try.
I researched the high poressure fittings/hoses for a 1981, 1983 and 1985 Toyota 2wd AND 4wd truck. The ONLY differences were the lengths of the hose. ALL high pressure hoses have a 16mm flared fitting on BOTH ends. I could not look up a OE FJ60 hose because of the facts given ealrier in the post. The return line fitting is a standard pipe thread #6. I found a barbed fitting, brass that is suited for the environment of PS fluid. Return fitting was 1.00.
All of the hoses, minus the 1981 Toyota 2wd HP hose, were too long. I mean we are talking one was 68" long. The 1981 Toy mini 2wd was 31.75". That seems perfect and that is what I imagine Pimp used. The part number for Napa is 7-1843.
Hope that helps someone in the future.
Thanks for your help guys
The return fitting on the box is not pipe thread; it is a flanged fitting. Pipe thread is tpaered and seals on the thread, while flanged fittings seal on the flange. A pipe thread fitting will not seal reliably in a fanged fitting hole.
Well, sh-t. So much for the expertise of the hose fitting company.
Napa states that they cannot make the return line fitting. So, what do I do? JT sells this piece for 30.00. Ouch.
Hi All:
Why don't you save yourself all this p/s hose grief and just use the p/s pump from a mini-truck with the mini-truck p/s gearbox? Then you can use stock mini-truck p/s hoses!
Just my $00.02
Good luck!
Alan
Seattle
