custom front bumper
Awendaw,SC
I whant to make a bumper and was going to use mostly 1/8" steel with 1/4" in other places. I have lots of deer around me and need good Rad. protection.
Any sug.
It is a 95
Yes, buy an ARB.
I think everyone that's built a front bumper has said it would have just been easier to pull out the credit card.
Yes, buy an ARB.
not quite but Im into tube not plate, plate steel seems to require more work for custom work
Drive backwards?
If you keep the hatch open you might score!
calstyl2's tube bumper is sweet, and has some awesome welds on it.. :) but for deer, I'd take an ARB over the tube/prerunner style for sure. Those things were designed to hit kangaroos and have the truck still be able to drive.. I'll second Doc, go with what works up front. my $.02
I am with Doc and Nakman.
I spent some quality time fabing my bumper, because it was my only solution.
Unless you have way more time than money (a plasma cutter, nice mig welder and a bit of experience sticking things together would'nt hurt either)
The ARB is your best bet for deer protection, it is designed for it.
Or you could go with a Slee Short Bus bumper and a 6 inch lift.....most of the White Tails in north america would fit below that.
The ARB is great protection from deer and other vehicles, but the approach angle sucks for wheeling and the mother is heavy.
If you have any fab skills a front bumper is pretty easy. Here is mine.
I have now started phase II which includes some extra recovery points, extra gussets and coming soon...hoops for lights and radiator protection. I'll update the linked thread when it's done.
calstyl2 - that tube bumper is SWEEEET!
FWIW, building a front or rear bumper is a fun project and can allow you use many of your own ideas, is there a perfect bumper built for rock, expedition, animal protection and what ever else someone has as a priority, the ARB or Slee Shortbus come pretty close, I built mine for crawling, the ARB not so much.
search MUD and you will find many ideas and see what it takes
Any sug.
It is a 95
Look at sunny belly or PM me. I have one that is short and sweet. It also holds a winch. The winch is placed back between the frames below the grille. All of it only reaches out 6" in front of the grille. That is it! Short and sweet!
My bumper and winch are closer than the factory bumper and work better. It is higher and gives more clearance, and still has a winch in it. Check it out!!
