- Location
- United States
Cummins 4BT Engine/700$4/FJ60-Splitcase
This is a complete running driving 4BT80 conversion take-out. Just about everything you would need to convert your 80 series (or 60 series) to 4BT. Low miles. Everything is either new or rebuilt.
Engine was rebuilt about 4000 miles ago. Serial #44202026. block was machined, new pistons, bearings, etc. Brand new head. New injectors, rebuilt turbo. 3200rpm spring. mechanical fan from dodge. Air con bracket to hold stock 80 series pump.
700R4 transmission. Professionally built with heavy duty clutch packs, heavy duty torque converter, mild shift kit. Has only 1000 miles or less on it.
FJ60 splitcase. professionally Rebuilt with new koyo bearings. Has only 1000 miles or less on it.
Beefy Radiator from Griffin. dual 1.5" cores.
3" intercooler set-up including all connectors and piping and such.
Motor mounts; bread-van liquid filled mounts.
Asking $7500. Located in Stockton, CA
Figure... would cost you...
$5500 for rebuilt motor/turbo
$1800 to build tranny
$600 for adapter
$500 for splitcase
$800 for parts and labor to rebuild splitcase
$500 for griffin radiator (no kidding)
$200 for intercooler
$500 for misc. motor mounts, piping, radiator hoses, belts, air-con bracket, etc.
plus another $500 for radiator, hoses, intercooler/piping, motor mounts, etc.etc etc.?
it would cost around $10k to build this kit. Hmmm, seems high, but... the parts do add up.
Prefer to sell as a kit.
$600 for adapter
$500 for splitcase
