Cruiser weight
Hoochie Coochie Goochland, VA
Hi, I've been lurking around for a while, and since I'm starting to tear down my cruiser for a frame-off resto and V8 conversion, figured I should probably go ahead and join. Like to say you guys have a wealth of really good info!
So I've removed most of the body panels and I'm quickly approaching the point where I need to get a floor jack. So how much does a cruiser weigh? What's a good weight capacity and what minimum height should I look for.
Thanks in advance!
Just go get a big one.
Teh bigger the better.
Cruisers weigh quite a bit. Some more than others..
3800lbs ish is supposed to be the stock weight.
Mine is probably closer to 5K
3800lbs is for the whole rig. with a floor jack your only lifting one end or the other. lifting height would be determined by how much lift you'll end up with. I use a 3 ton, picked up new for $60. works good for what I need.
I got this one a few years ago and I have no complaints: Harbor Freight I'm usually only lifting one corner at a time, but sometimes the whole front or rear end. No problems.
I really wish I had the money for a long frame jack that'll go up to 30": here
I would NOT get one of these for a cruiser. Not enough lift and not stable enough in my experience.
Of course, if money wasn't an issue, I would get something other than Harbor Freight, but I've been impressed with my jack.
You need a 2 ton engine hoist (cherry picker).
Nocents
