cruiser turned on by itself
Rio Grande Valley, Texas
Has this happened to anybody. I got back from running an errand, turned the car off, went into the house had lunch and was jumping into another vehicle when I noticed the cruiser was running. Went over to it and it was locked and running. I went back inside the house to get the key for it and opened it up and it was running, key was not in the ignition. I had used the fob to initially lock it when I went inside for lunch SO it was not left on by me. I am due to go to a funeral in a few minutes and I am concerned what if it happens again. In the meantime I am going to disconnect the battery. If someone can offer some info for me it would be greatly appreciated.
forgot to mention that vehicle does not have that dodad that turns it on via the fob, remote start I believe its called.
It must have the remote-start option. Too many things have to happen for the car to be running by itself. The ignition circuit has to have power, and the engine has to turn over. I could see a short in the wiring somewhere causing either of these two things to happen, but not both at the same time. Too coincidental. The only other explanation I can think of is that it was still running when you removed the key, which is doubtful but more possible than spontaneous start-up.
-Spike
What Spike said... I would investigate the ususl places where an aftermarket remote start or alarm system could have been installed. Under the dash, by the steering column, kick panel. Check out the wiring around the ignition switch for any signs of aftermarket tampering. It could be possible that someone before you had a system installed & just did not give you the remotes. Your vehicle could start if someone was arming or disarming their vehicle nearby & had the same or a "rolling code" frequency. Unlikely, but possible. I still have not seen anyone spontaineously combust. LOL:bounce2:
thanks, I figured it had to be something like that, the PO never mentioned whether the car had remote start or not and I have tried all the buttons on the fob to see if I could get it to start remotely. It does not. I will check the wiring as mentioned.
What does your remote look like? Is it the factory toyota one or an aftermarket? It may be a combination of buttons to start it. Or perhaps pressing one button 2 or more times.
On my Toyota mini you could remove the key without shutting it off, it was just worn. My 80 has a remote start, very handy (expect when the kids get it and I hear the truck mysteriously start while I'm watching TV).
chitty chitty bang bang
My remote is the standard issue viper type alarm fob. two buttons. first button activates and disarms alarm. second button to the best of my ability does not appear to do anything. I will try pressing the buttons in different sequences to see if anything causes it to start again.
Paint a #8 on the rig, call it Ocho or Herbie and go with it!
On the 2 button viper I bet if you press both buttons at the same time it starts.
Well what do you know, I have remote start, PO never mentioned this to me. I went out and pressed all the buttons in different variations and on my two button viper remote, the second button when held down for 5 seconds turns on the vehicle. Pressing the brake without the key in the ignition shuts it down. Thanks for the help. Problem solved.
I thought it just wanted you to take it to the mud...
Damn them Cruisers are smart.
Thats cool. You may want to try and start your truck while sitting inside & in gear. Be careful, just in case it takes off. It should only start in park with the E-brake on. I saw a car start while in gear (M/T) & it went up and over a parking curb.. :doh: It sure is nice to have the remote start when its extremely hot or cold out.
