Cruiser lean?
I had the cruiser lean on my FJ40 years ago.
Well now my stick 1996 has a pronounced ds lean in the rear.
Any ideas? Time for new springs?
Yep. New springs.
OME or new factory are your basics.
OME does/did stock height in normal compression & a heavy rate if you think you could use a little help or carry gear normally.
Slee is the OME expert in the States, or so I seem to think from all Christo's posts over time.
How much of a lean do you think it has now? If you want to bandaid-it, you could add a coil spacer to the low side, but that's $40 or so. For $175 you can get new coils.
