Cruiser Day 70/60/40 Series Parts
Kelowna, BC
I have 70/60/40 series parts for sale, including new Toyota OEM parts discounted to the US Toyota dealer price. Let me know what you are interested in and I will bring them to Cruiser Days July 18th.
NEW TOYOTA PARTS
1. Water Pump NEW - 13BT/3B Toyota (part# 16100-59105) price $130.00, US dealer price $130.00 USD ( $170 CDN), Toyota Canada price $273.00. Fits BJ40/BJ60/HJ60 LJ70, BJ74.
2. VSV shut-off valve - 70 series (LJ/BJ 1984-1989) (16100-59105) Rare Part special order from Japan- NEW - $60.00 - used they sell for $45.00 if you can get them
3. Pilot Bearing 13BT OEM NEW - $5.00
4. Oil Filters 13BT/3B OEM (x3) NEW - $5.00/ea.
5. Fuel Filter 13BT OEM (x1)(2303-54072) -- $20.00, US dealer price $26.00 USD.
6. Front Brake Pads (60/70 series) (old# 04491-60010) -- $65.00 - US dealer price $65.00 USD
7. Front/Rear Inner/Outer Wheel Bearings -KOYO 70/60/40 series, 4 NEW, $120.00 compare to US dealer $166.00 USD)
8. Birf Rebuild gaskets/Felt kit, -no bearings, pair wheel bearing seals - $30.00
9. Rear Diff gaskets Free
10. Clutch Master Cylinder kit (04311-60042) fit 1984/89 60/70 series Rare Part from Japan ($35.00)
11. Clutch Booster Seal grommet fit 70/60 Series 1984/89 (44621-28120) - NEW $8.00
12. Brake Master Cylinder kit (04493-60170)) fit 1984/89 60/70 series - $50.00 US dealer $62.00, Toyota Canada $162.00.
13. Rear Door hinge cover (68851-90KOO) NEW $5.00
14. 13BT Alternator Belt (Heavy Duty Mitsubishi) NEW $30.00 (better fit than NAPA - lasts longer).
15. Transfer case gears from Marks upgrade low KMs
USED PARTS
1. BJ74 Rear Driveshaft (shaft and 2 OEM U Joints)- $80.00 (U joints are $115.00/ea in Canada)
2. 70 series Rear Axle Shafts (right and left side) -good condition (x2) - $50.00 each
3. 70 series Birf and short side front axles - trail spare - $50.00.
4. 70 series Front Spindles (x2). ($30.00 each) good condition
5. 70/60 Series Split case T-case/transmission oil line return hose (x1) - $55.00) allows time until T-case seal is replaced, to prevent other seal failure.
6. 70 series radio antenna (x1) --$5.00.
7. 70 series grab handle (x1) - $5.00)
8. Hella H4 7" headlight lens (x2) -good spares- $10.00 each
ARB Air Locker Parts (new)
1. ARB compressor pressure shut-off switch (70psi on/100 psi off) (price $30.00) ($41.00 USD Amazon.com)
2. ARB air line repair kit (ASK001) (x2 couplers and blue air line) $30.00 ($32.00 USD Amazon.com)
3. ARB single line coupler repair $10.00
4. ARB anti-kink spring retainer diff fitting (x1) -they corrode ( $8.00)
5. ARB locker switches (x3) ( $10.00) ($17.00 USD Amazon.com)
Electrical
1. SCHAUER 24 VDC smart charger (7 amp) -- $55.00
2. H4 - 24 volt Hi Output 90/100W headlight bulbs (x2) -- $10.00 each
3. H4 - 24 volt 75/75W headlight bulbs (x3) -- $5.00 each
4. H3 - 24 volt - 70 watt ($5.00
5. 24 volt 21 watt bulbs (x7) ( $1.00/ea)
6. 24 volt 5 watt
Misc Stuff
1. OME Poly leaf spring bushings kit (8 pieces) NEW ($30.00) - they wear out
2. FireStik CB antenna quick disconnect NEW ($5.00)
3. Scepter diesel 1 1/8" pour spout with black case $30.00
4. Scepter diesel can gaskets (x2) - $8.00/pair
5. Dynabeads 8 oz balancing beads (2 oz. per tire) - $18.00
6. Self Siphon (Jiggler Hose) 12' hose NEW - $18.00
7. Aircraft cable for limb risers 80' of 1/8" $10.00
8. Hi-Lift Lift Mate wheel lift attachment ($25.00) - lifts wheel not the suspension.
9. SanDisk Ultra microSDXC UHS I 64 GB (NEW, in case) ($25.00 Amazon.ca cost $36.00)
10. 12' x 20' Midland canopy (1 3/4" gal pipe, foot pads and snow load reinforcement) heavy duty ($425.00 cost me nearly $800) - Excellent shape. Unlike many other canopies all the parts are all replaceable, top and sides all replaceable. This is a heavy unit - not hauling it to the Lower Mainland unless someone wants it for sure. . http://www.midlandcanopies.com/pavilion-canopies/
Hi Glenn,
I will take:
Rear Diff Gasket
6. 24 volt 5 watt ($1 each?)
Total: 15+20+7+? = $42+?
:beer:
This stuff is a flying off the shelf. I will prioritize the orders for duplicate requests .
Well, most of us drive outmodes, you know. ;)
It was a more humorous reference if you've seen this film....
If not already spoken for, sign me up.
The general use items, would be good for prizes ?
The front pads are going to Kim - you got the water pump (they go at around 200k).
It is the OEM T-Case gears I have - the marks went with the truck.
This is what is left. I will honor the reserve till 11:am - after that its back up for sale. I am leaving Wed at 11:00 am.
NEW TOYOTA PARTS
1. Rear Door hinge cover (68851-90KOO) NEW $5.00
2. OEM Transfer case gears from Marks upgrade low KMs
USED PARTS
5. 70 series grab handle (x1) - $5.00)
1. ARB compressor pressure shut-off switch (70psi on/100 psi off) ($32.00) ($41.00 USD Amazon.com)
2. ARB locker switches (x2) no fronts ( $10.00/ea) ($17.00 USD Amazon.com)
Electrical
1. SCHAUR 24 VDC smart charger (7 amp) -- $55.00
2. H4 - 24 volt 75/75W headlight bulbs (x1) -- $5.00 each
3. H4 - 24 volt 60/55W headlight bulbs (x2) $5.00 each
Misc Stuff
1. OME Poly leaf spring bushings (8 pieces) NEW ($30.00) - they wear out
6. Aircraft cable for limb risers 80' of 1/8" $10.00
7. SanDisk Ultra microSDXC UHS I 64 GB (NEW, in case) ($25.00 Amazon.ca cost $36.00)
8. 12' x 20' Midland canopy (1 3/4" gal pipe, foot pads and snow load reinforcement) heavy duty ($425.00 cost me nearly $800) - Excellent shape. Unlike many other canopies parts are all replaceable, top and sides all replaceable. This is a heavy unit - not hauling it to the Lower Mainland unless someone wants it for sure. . http://www.midlandcanopies.com/pavilion-canopies/
Matt - you got the 'Jiggler' hose to play with when no one is looking - Kim got the wheel bearings and birf gasket kit
Ignoring that inappropriate (i.e., retarded) comment above, people asked what was left.
NEW TOYOTA PARTS
2. 70 series Rear Door hinge cover (68851-90KOO) NEW $5.00
USED PARTS
Electrical
Misc Stuff
3. Scepter diesel 1 1/8" pour spout with black case $25.00
4. Scepter diesel can gaskets (x2) - $5.00/pair
The canopy is spoken for.
