Cruise Control Question - multi function switch issue?
Iowa
Have a 95 FZJ80 and the cruise control worked with the exception of turn signal kicking it off due the LED brakelights up until the other day. Now I have Nada. Green cruise light doesn't light up and all of the threads I have seen describe the light being on but blinking when trying to set the cruise. All the fuses are good and no other issues that I can see. Other than the Head Gasket, any ideas?
Mine worked some of the time, would cut out when hit a bump--sometimes. Changed wheel bearings/seals and brake assemblies, now cruise works perfectly. No idea why.
I wonder if the abs sensors were gummed up with metal shavings or something.
It worked after I did the front axle and rear axle over the last year.
No warning lights for the ABS and the only CEL is an intermittent one for the exhaust because the PO deleted one of the CATS and the other is ready to be replaced. It had worked for the year I had it with the LED tail light assembly so this is something new unless it finally became a bigger issue because of that. I don't have the non OEM tail light assemblies. If it does end up with that, I can live without the cruise for the $300 or so it looks like the tail light housings would cost.
LED brake lights shouldn't affect cruise control, pressing the brake will always cancel it LED or not. LED turn signals do cancel the cruise control though.
True. But he’s getting no cruise control at all now apparently.
That's what I was afraid of; he's probably not going to make it past step D: "check that the indicator light "CRUISE" lights-up in the combination meter."
Definitely worth a shot though...
My CC was sometimes intermittent so I DL the testing instruction and its worked perfect ever since without testing:hillbilly:
I’m sure I didn’t do it right but I got to step 4 and no cruise light coming on. This mean a bad switch?
Back to the top. Still no worky....
