crossmember help
Lancaster, CA
Hey everyone,
I just installed this 5 speed/split case in my 45 project. I was able to use the bell housing mounts, but I'm wondering if I need a crossmember for this? If so, where would I find one? It just seems awfully heavy for just the bell housing mounts and 4 tranny bolts to hold this thing in place.
This ^^ , but I would say it takes quite a bit of mods to the 60 cross member, at least on my '79 40. My 5 speed conversion did not use the bell housing mounts, so I absolutely needed the cross member. Multiple cuts made in the original to get the bends where they needed to be, then welded to keep the shape.
Since it looks like you are using the stock bellhousing (that doesn't clock the transmission 3 degrees) then you could use a 8/80 and newer FJ40 transmission cross member. You might have to mount the brackets a little lower to make sure the higher shift tower/top cover clears your inspection cover or doghouse (don't know what year 45 you have).
Probably plenty of Late 83+ FJ45 crossmembers is Australia. The HJ47 83+ should work. Never done a exact measurements but width of the FJ45 and H47 are close. Not sure if I'm going with a five speed in my FJ45 but will be 8/80+ transmission with split transfer case. Also going with a PTO winch so will not hang it off the bellhousing. Been a few threads on the differences in the 8/80 4X series crossmembers.
I have an HJ47 3 piece crossmember but might be going in a different direction with my 1HZ/40 build. PM me if you’re interested.
sent you a pm
