Front axle right side, check it for cracks. The axle if not repaired can brake on half, and it is common on 80s.
I fixed mine already twice.
Sorry English is not my first language, usually is starts on the ear on the housing. It is a first sign. And if there any crack it is the sign to take the axle off and inspect for cracks all over. Bending housing it is one thing. Driving in harsh conditions causing the axle literally fall apart it is another thing. I have not seen, but couple of 80s owners, my shop knows well, had the axles breaking during driving. I will be visiting the shop today and I will take few pictures.Woah, you can't toss out something like this & not either explain better (heck, even if you mean the housing, a welded ear on the housing, etc..)
I've bent the housing, and Christo has a few to his name as well, but nobody has talked about breaking one.
Also, not to go spelling Nazi on you, but in your context & brevity of description, if you meant "break" not "brake" - then where & what "breaks" or are you welding something on your "brakes"?
.....And when I posted about caliper bolts I did so just as many in the decade-some-plus of being here, I've seen like 5ish posts about people finding missing bolts after working on their 80's (prob were doing FAS/birf work, I don't recall).
My fix for it is I just toss some blue threadlocker on the bolts, and run an extra 5 ft/lbs over spec, then recheck after a couple days /50-75 miles. No issues, calipers been off somewhere short a dozen times or so, maybe more when you include my old bigger LX450, it saw many days of me on my back on cardboard, etc.
Tugarin: can you describe the conditions, location (in the world), and situation that caused the axle housing in the photo to crack like that? Was the vehicle in an accident, driving on dirt tracks in Mongolia, ---?
Axle housing damage is a known issue everywhere else in the world specifically at the front control arm brackets--they shear away from the housing itself.
Happened to my 80 front (nothing like the above picture). Happened to Robbie's 1993.
Toyota upgraded the bracket on the 105 series iterations (that housing is available in the US market). @Cruiserdrew has a new upgraded housing in his 80 series.
You need to drill extra 4 holes and put threads if you want to put 105's axle into 80. The gear housing has different bolt pattern.
After reading this thread last week had a guy shear the studs this weekend. Looks like two backed out then sheared the others. Luckily it was on a flat section and just veered into the bush. we able to pull 2 from the driver side and get back home safely.
Sorry- which studs??
