This is very weird. I was working on my sister's FJ80 today. Basic maintenance, oil change, air filter, top off fluids, blah blah. On her way home, it started acting strangely. Mechanically, everything worked fine. However, when slowing to a stop, once speed would get down under 10 mph, a bunch of warning lights would come on. A/T Oil Temp light, Brake light, and the square-shaped red warning light on top of the voltmeter. Always all three together. If she manually shifted to Park or another gear, they would intermittently go out, but usually stay on. Again, always all three together. Start driving again and they go out. WTF?
These are the only two thing I did during the course of the day that I could even remotely think might be a possible cause:
1.) On the 3F-E (at least in the 80) the oil filter is up on top of the block, vertical. Kinda nice being high up, but taking it off unavoidably dumps some oil downward. I got some on a wiring plug that looks like it goes to the power steering pump, or runs right by there.
2.) I found the previous owner had apparently lost or broken the fuse box cover, and had put a tupperware cover over it held in place by wire. Not the best splash or dust guard. I took it off and was blowing compressed air in there, and a lot of dust came out.
I'm going to have her disconnect the battery to reset the ECU, and then pull all the fuses in the box and WD-40 them, but not sure what else to do.
TIA for any help,
TIA for any help,
