Crap - coolant issues
Sandy Utah area
So I had my all my fluids baselined about 3 weeks ago and tonight as I turned off the truck I thought I smelled coolant, and I had from time to time other times driving as well so I open the overflow and found this, and only this. This is all the fluid that was in there. it smelled like Toyota red, not oil, but it was opaque and dark and had a somewhat higher surface tension as well as a lot of sediment in the res. The normal response to this would be "time for a new HG" except it is a new HG, its less than 26,000 miles old. I had a shop rebuild the top end completely about a year and a half ago. The radiator, t-stat and water pump were all replaced then too. its literally a 100% new cooling system minus pipe.
I checked on the coolant from time to time in the past and it always looked fine, good levels, good color, and even after I had it baselined it looked good so this is a very recent thing. Could there be something other than a bad HG causing this? Backflush of old clogged lines? coolant going...I don't know.
Second, and advice on bringing suit against this mechanic? about 50% of his work has needed to be redone in the last year and its clear to me he wasn't the Toyota expert I thought, or at least the guy working on my truck that day wasn't terribly interesting in doing it right. His paperwork says 1 year parts and labor warranty but do I have any claim beyond that?
That does look like chocolate milk oil. Was the head gasket blown before and was the reservoir completely cleaned out? Maybe you just have a leak and it sucked up all the coolant into the engine out of the reservoir leaving the old sludge from before. If it's clean under the cap, hopefully just a hose clamp leaking or something.
What do you find under the radiator cap? Are you certain they used an OEM head gasket?
The cap had some gray stuff on it, kinda looked like rtv? Coolant still smell like toyota red and it doesnt feel very oily. The coolant in there was fine until recently when the coolant was changed, the sediment issue was always a little present even after the new rad but it does make we wonder where its going
Cometic HG...OEM HG? What work needed to be "redone"?
They didn't list the gasket, but the shop is know for using only genuine parts, it wasn't cometic. The front axle is pretty badly messed up including but not limited to a bad wheel bearing that wrecked a spindle, a gear install that is only getting louder and louder and producing metal shavings (as well as tearing the 3rd member seal so it leaks) and a few smaller items.
If it's oil, the oil cooler is a possibility, a few of them have leaked.
Just got off the phone with my mechanic, no hydrocarbons in the coolant, it looks like its residual junk from the flush (and likely from the PO's mixing of coolants) and the loss of coolant is from the rear heater valve leaking. Dodged a bullet there I think. Still not happy with the old shop, but so long as their HG job holds, I can be satisfied just not going back there again.
My (old) head gasket allowed oil to mix with the coolant, and after replacing it, it took several weeks and multiple flushes to finally get all the residual oil out of the cooling system.
My definitive "tell" that my headgasket was gone was a LOT of smoke and rough running on startup ... which cleared in about 30 seconds. This is due to shutting down a normal running temp engine followed by the built up water pressure forcing coolant into the piston (s) ... other early indications might include an occasional stumble/roughness while driving ... and (occasionally) blowing the seal on the rad top header housing. If you have had to replace a rad ... and you haven't done the HG ...be cautious. And one interesting thing that happened to me ... when my rad header seal failed it sent coolant to the back of the block via the inner engine hood insulation
My definitive "tell" that my headgasket was gone was a LOT of smoke and rough running on startup ... which cleared in about 30 seconds. This is due to shutting down a normal running temp engine followed by the built up water pressure forcing coolant into the piston (s) ... other early indications might include an occasional stumble/roughness while driving ... and (occasionally) blowing the seal on the rad top housing. If you have had to replace a rad ... and you haven't done the HG ...be cautious
I have had the HG done, It sounds like its likely not the HG.
Just an FYI ... there is no rear heater valve. Only one heater valve that controls water to the front passenger and rear passenger heater cores. If the rear doesnt want heat .. dont turn on their fan. BUT certainly coolant leaks from that area is not at all uncommon. the simplest fix is if one of the crappy OEM "pin" type clamps need replacing and they do NOT do well anywhere they use salt on the roads, .. it might be a simple inexpensive fix. It was for me the first time ... But when I looked at how thin the tubing was and the exterior condition .. (as much as I can use a rear heater here in Canada) I disconnected the lines to the rear when I did my HG as a preventative measure. .. I read about people "bypassing" the rear heater .. not sure how smart that is if I understand what they are doing because as far as I can see all that you do when you bypass is provide a quick short route for coolant and (potentially?) reduce flow to the front heater core... now that I have "disconnected" the rear lines .. my heater blows very hot air.
You are correct its just the heater valve, but its the rear lines that are gross and the actual valve is cracked. I really like my rear heat, so Im having a new valve put in.
  • Like
Reactions: AJP
