Has anyone developed an oil leak around this? I believe i have and looking through the FSM it doesn't show a gasket that can be replaced.
RavenTai said:Thought I had a leak at the crank sensor cleaned the area and found I had several small leak around the front of the motor that dripped down to that area over time.
RavenTai said:Is the O-ring physically not replaceable or is a replacement just not available through Toyota?
or several
?Rookie2 said:Any particular reason you've ruled out the pan seal?
