I have the socket for 2F probably for F. I also have the bracket for the bumper for the crank to go in.
The threaded rod looks like a fine design, as you could really cake the threads with grease, and I'm into making threads more than burning welds, but a spot weld on it would keep it from rattling around with everything else. The handle with hex, it wouldn't fit like the original one did on the fender well, and I have a couple of clips too. This would explain some differences between trucks, 40, 45s, 55?
I was just wondering, because a four-stroke-gas-engine appears to go the other way when it diesels and you have no idle cut solenoid or whatever. Ignition timing occurs during the compression stroke. If it happens too early, you could see how it might stop the piston from compressing the fuel charge, and maybe spin the crankshaft the other way. I don't know if this is what I'm observing, but, it would be a bad experience if the engine kicks back, I could imagine.
