Crankshaft Bolt Removal
Central NJ
Dumb question but I want to be absolutely certain. Is this a reverse thread bolt or not? Fabbed up plate to go over passenger side frame rail and have 3/4" breaker bar on way. (No guts for starter method) Do I turn bolt counterclockwise facing pulley or clockwise (reverse thread). Lately I could screw up an anvil so I'm checking every step of the way.
Go with the starter method as described in the FAQ! I was very very nervous about doing it as well and in fact put off the project for that reason. But in the end I bite down and gave her hell. Worked like a charm! Just follow this thread..... https://forum.ih8mud.com/80-series-tech/72514-how-replace-oil-pump-seal-w-pics.html it is a great guide.
As far as the thread direction on the crank bolt....I am drawing a blank even though I know it should be obvious....guys?
The starter bump method is inherently dangerous and should be carefully thought through. Do not use anything smaller than 3/4 inch drive. You will break the bar, don't ask me how I know that.
Now I want to ask Dan!!!!
But in all seriousness...use caution when using this method!
Safety First!
Dan, did you take a photo of whatever the ragged end of the bar torn up as it spun around?
I broke a heavy-duty 1/2 inch breaker bar and that was with the bar tied tight to the frame rail. It did not slap the rail, the starter snapped it like a dry twig.
I was able to loosen the crank bolt on mine with a 4ft cheater bar on the end of a 1/2" breaker bar without too much problem.
Then again, I am pretty huge at 150lbs soaking wet. :cool:
The bar snapped right where it swivels. Fortunately the handle fell to the ground after it danced around a bit.
Off to Sears I went to get a free replacement (Craftsman) AND a 3/4 drive bar. :p
No one was near the front of the truck when it happend so a detour to the ER was not necessary.
That is a different kind of pressure peak than hitting it with a 2.2kw starter.
