I am doing the HG on my 94 and ran into a problem getting the distributor out. I removed the bolt through the elongated slot and thought it was a little weird when I wasn't able to rotate the distributor or pull it straight out. I sprayed PB Blaster on the mating surface between the head and the distributor and on the distributor shaft that goes through the wall of the head. It didn't seem to help the distributor rotate or come out of the head. I started tapping the back of the distributor housing with a hammer and brass drift and was able to get it to move about 3/8 in. before the distributor housing cracked
A couple of questions:
1. Why would it be so difficult to get the distributor out in the first place?
2. How do I get it out now that it's broken?
3. Will the distributors from 95-97 trucks work on my 94? (I'm pretty sure they will but want to be safe if I get a used one.)
4. My local dealership just quoted me 527 for a new one
Any and all help will be appreciated.
Neal
Neal
. Nat, I may need your spare. I have been looking around for a used one. Let me know if you come across it.
. I'll try again tomorrow. I probably should have been more patient but i was making no progress untill I started hitting.
