Hey
My 71 FJ started running rough. I found that the manifold flange was cracked near one of the studs and into the plenum. I used some high temp silicone as a temporary fix. It is completely cracked through and leaking. A couple of questions:
Does anyone have experience using the aluminum brazing rod? I have seen a demonstration and it looks easy to use. It is said to be as strong as the aluminum but I have my doubts. I found very little online other than "its stronger than the base metal". In real life, can this actually work.
If I go with a replacement does anyone know the range (by year) of manifolds that would fit? It's used off road only so smog compliance is not a real issue. I noticed there are wide and narrow runners. I think either would be ok, with a preference for the narrow one. Since its a ranch truck, it spends a lot of time at idle and low speed. If I could pick one up at a reasonable price that would be my preference. I have looked at a couple of the forum vendors and on ebay, found little and found nothing reasonable.
Any help would be appreciated.
John
John
