correct steering caster durring a SOA
Colorado Springs
I am currently in the process of performing a SOA with S/R on my 78 FJ40. The one thing that I have yet to figure out is what to do about the caster. The axle was already off the truck so I do not have a basis to go from. For all you brilliant cruiser heads out their here is my question:
What is the proper caster for a FJ40? and how do you do about measuring one/setting it correctly.
I would like to weld the spring perches on so that I do not have to use shims. Thanks for all the help!
Most like to run between 3 - 5 deg of caster on a SOA with 35" and over tires.
Some things which you will need to decide before you set your caster. Are you flipping the spring? Are you doing a shackle reversal? Are you going to cut and turn?
Once you know the answers to those questions and hang your springs on the truck you are ready to worry about setting your caster. Whatever you do, don't cut off your stock SUA spring perches until you are ready to set the caster as they are your baseline for stock caster reading.
Welcome to Mud! :flipoff2:
The official definition of caster is the angle through the center line of the knuckle bearings, with respect to verticle. There are several ways to measure it with varying degrees of accuracy.
1) An alignment machine (most accurate)
2) The flat top of the installed knuckle is perpendicular to the caster angle. You can put a straight edge on the flat and measure the angle with a magnetic base angle finder.
3) The surface of the knuckle bearing races are also perpendicular tothe caster angle. You can measure the angle here, but since the base is narrower than the knuckle flat I don't think the measurement would be quite as accurate.
You can also measure the caster angle relative to some fixed position, like the stock spring perch flat. The stock caster angle is +1, so you can use the stock perch as a reference point to see how much you have turned the knuckle.
