Correct Coil Hook Up?
Rig: 1978 FJ40 2F
I just installed this new coil from JT Outfitters: Land Cruiser HP Coil - JTOutfitters
The PO had the old coil set up this way so I wanted to make sure I have the wires on the correct terminals. I'm not familiar with what a yellow wire is for but the red and black were easy enough to determine. I also just discovered this coil is not internally ballasted so I'm pretty sure it's not the correct coil since I've read on this forum if you are running an electronic ignition conversion (which I am) then a ballast resistor is needed. My rig never had a ballast resistor on it from the PO and he was running the OEM coil. Any feedback is appreciated.
From memory, a ballast resistor is used to prolong points life.
The newer electronic ignition distributors need the full 12v to operate correctly.
First option. if you have a coil that needs ballast [reduced voltage] it should be wired with the ignition + flowing through the ballast resistor to the coil +
and full 12v going to the + of the electronic distributor.
With a newer 12v non ballast coil both + 12v ignition go to coil+ and distributor+
Both types of coil will work ok if wired correctly.
I think thats correct. This is how I wired my reluctor type dizzy and used my existing ballast coil [first option].
also with first option the starter solenoid remote relay wire needs to be connected to coil+ [this is universal with ballast coils] to give extra volts when cranking
also with first option the starter solenoid wire needs to be connected to coil+ [this is universal with ballast coils] to give extra volts when cranking
By chance do you know what the OHMs should be on the coil for a 2F engine? I have searched but cannot find how or what determines the OHMs of the electronic system on our rigs. I see there are 2 options for coils. 1.5 OHMs on the primary and 3 OHMs on the primary. The one I currently have installed states it is 1.4 OHMs on the primary.
from FSM
The coil that you linked to imo requires a ballast resistor [1.4 ohms figure]. Might be advisable to ask them. Its a bit ambiguous with the "ballast resistor not supplied" comment. It may function fine with or without ballast, and adding a ballast might only be advised when using points.
‘78 has a big pink (8? ga) Yazuki (sp?) resistor wire spliced into the big BY wire.
It’s all wrapped up in your harness, between the PS fender and the gauge cluster, IIRC.
I no longer have a separate coil setup and can’t fully recall the wiring.
The only reason for a ballast resistor is to enable a resistor bypass circuit that improves starting in cold weather.
If you run a coil that requires a ballast resistor without one, the coil and points may burn out.
Gotcha but I'm not running points. I'm running the electronic ignition conversion which is some type of a mod hack from JT Outfitters who uses parts from a Pertronix Ignitor kit. Hree is the link: Mel's Electronic Ignition Conversion Kit - JTOutfitters
The irony is everything I read about switching to electronic ignition conversion says a ballast resistor is not needed yet Pertronix recommends their Flamethrower Coil which ironically is "internally resisted".
The yellow wire is probably the link from the starter solenoid. It supplies full 12v to the coil when cranking, bypassing the ballast resistor .
If it is bypassing the ballast resistor would that mean it connects to the ballast resistor if I had one on there? I'm still not clear on when a ballast resistor is or is not needed. I read so many conflicting opinions. I've searched online as well and this same question is asked across all older trucks and cars. I've read the same debates on Mopar forums, GM forums, Jeep forums, etc. Everyone says similar things but the recurring opinion I see the most is if the vehicle is running points then a ballast resistor is needed and if it is an electronic ignition conversion then a ballast resistor is not needed. I'm trying to determine why my engine keeps shutting down after running for around 15-30 minutes and it has something to do with heat. Coil and ballast resistor or no ballast resistor is where I am at the moment after having replaced multiple other parts chasing this issue.
I agree with you it would seem the coil I have should also have a ballast resistor. And I did call them and ask them but they said the one guy in their shop who would know is currently on vacation. I should find out sometime at the end of next week when he returns.
anecdote here. I put a used 3f in my fj73 and the electronic ignition was wired incorrectly. The igniter was wired from the resistance end of the ballast. 8v or thereabouts. It would run for about 30 mins and then break down. I did some research and figured it out. The module in the dizzy needs 12v.
the post from pngunme above is interesting. If the ignition is going through a resistance wire in the loom, then it complicates things
I had no idea this was used in replace of a ballast resistor? If true it could explain the problems you have after running for 30mins. [lower voltage to module].
You could use a relay activated from ignition to supply the full 12v to the dizzy module
You could use a relay activated from ignition to supply the full 12v to the coil.
Read posts #128 & #132 HERE
That same thread discusses coil wiring... Maybe it would help to read thru it.
You can trigger a relay with the small BY wire and feed the full 12v from the battery to the coil... Only the large BY is resisted by the pink Yazaki resistor wire.
Thanks PNG...this is very revealing and helpful. This engine shut down issue has been eating me up and nothing seems to correct the problem. I have read through the thread link you provided. I really appreciate it.
To test the yellow wire function. Disconnect it from the coil+ and connect to a test light to earth. If it lights up when cranking the engine it is correct.
This wire is not connected to ballast in any way,
Another thing to try is connect the red wire from the dizzy to the battery + and go for a drive. If the shutdown problem goes away it's a good bet that the module wasn't getting enough volts.
hope you get it sorted.
Are you sure your yellow wire isn't spiced into some other OEM color?
Here's the OEM wiring schematic portion for the coil and igniter.... No Yellow
The full schematic is HERE
You don't show an igniter... does that coil require an igniter?
Does JT Outfitters provide installation instructions for that coil?
I replaced my dissy, coil and igniter with a DUI... It required a full 12 volts. As I said earlier, the large (10ga) BY is resisted by the Pink Yazaki resister wire. I no longer use the large BY wire.
I used the small (14? ga) BY wire to trigger (terminal 86) of a relay... The small BY is activated by the ignition.
Terminal 85 is grounded.
Terminal 30/51 picks up the full battery voltage and is fused... Terminal 87 sends the battery voltage to my DUI, when terminal 86 is triggered.
I don't know how your coil and electronic ignition is supposed to be wired... I hope some of this helps.
