Copper or Stainless nuts for O2 sensor
Maine
I have read most of the O2 sensor threads and seems copper or stainless might be the nut to use when replacing O2 sensor. Anyone having problems mixing dissimilar metals. I am concerned that I may damage the threads on the manifold posts if I use SS. My O2 sensor poped out on a 550 mile trip home. Wired it back in but I am guessing they have never been changed (nut must have rotted off) and at 185K should be. O2 threads are a great help. Thanks
I wouldn't use copper. If you think the steel nuts rotted off quickly, wait till you put the copper nuts on :eek:--especially if you live anywhere they use salt.
In a previous career I built a bunch of air cooled VW's, on the exhausts, headers we used copper plated self locking nuts with good success. Check VW aftermarket parts houses, they may still be available?
I used copper when I just did this. Supposedly the copper is supposed to keep it from backing off. They were a real PITA to get the originals off. I did use antiseize on them too. It was a terrible job.
Use Copper for 02 sensors
Ask any exhaust shop why not stainless. After SS is on for a while, it will never let loose. Copper is used because during removal the chances of you buggering a stud or backing out a stud during removal is low. Yes they deteriorate faster than steel. That said, 12 years in Chicago salt, and I removed the coper ones from my 02 sensors. If they last half that time with new, I'd be happy.
The dealer should have these in stock. Or, any vw/audi dealer should have them as well.
HTH
ST
Hmmm...
How about using a sacrificial annode? Could you use stainless, and then put on an extra zinc nut to protect the stainless? You could cut the zink nut before putting it on so that you'd be able to get it off after it corroded.
I'm not sure if this would work, but with all the corosion you guys get up north I'm surprised no one has copied the lead of boaters.
T.
Thanks folks..looking for copper ones!
Not sure of the dia. or thread pitch though.
ST
Nickel or silver (Ag) antiseize takes care of that. high quality stainless nuts used in high temperatures are silver plated.
http://www.bostik-us.com/TDS/TDSFiles/NSPureNickelSpec.pdf
Meets Boeing BAC 5008, Ford ESE-M12A4-A, Garrett Engine Div. PCS5721, GE Aircraft A50TF198 Class A, General Motors 14001899, Pratt & Whitney PWA 36053-1 and is tested to MIL-A-907.
Something like this?
http://www.discountvdubparts.com/VW_Exhaust~Nut_list.html
http://www.bildon.com/catalog/DetailsList.cfm?ID=253.104&Nav=7
RT, Mil Spec A-907 takes care of heat, not vibration , expecially on exhaust related stud hardware. If you look at what Audi and Porsche use for turbos, you see titanium hardware for massive thermal expansion, and metal trap inserts in the attaching nuts. Downstream they just use copper nuts on steel fasteners/studs.
Copper one of the bases for Mil spec A-907 Antiseize anyhow. I might also caution that "antiseize takes care of that" in relation to 02 sensor failure. The nuts TRU listed are available at the vw dealer, and I actually prefer the ones from Toyota as they are much taller.
Any 8x1.25 nut will work, in this case what Mr T delivered isn't cost prohibitive and is found in exhaust systems quite regularly.
ST
You can also get brass nuts from your local boat dealer. Same principle as copper, but they will withstand the corrosion better. I use them on the bolts that hold my outboard on, and they see a lot of salt air in the local bays, no evidence of corrosion yet. no jokes about brass nuts, please.:D
ST
It is advisable that you read the information presented before you shoot your mouth off. It is obvious that you did not.
It was tested to MIL-A-907 meaning it meets the performance requirements. that does not mean that it IS MIL-A-907, it does not contain copper and yes it will hold up to much more heat and vibration then your precious Audi's could muster.
Titanium hardware would be great, lightweight and excellent heat and corrosion resistance, great for a race car. But low strength and my budget would not allow it. You would certainly still need ant seize with it, Titanium threads like to gall and lock on same as stainless.
Having said all that I used Toyota nuts from Cdan, in the absence of road salt they lasted 10 years and 160K miles on my 80 in great shape. I did use some special Anti-seize.
RT, with all due respect, Mil Spec A907(E) really is a corrosion and heat spec. With all due respect too, most copper based antisieze compounds also pass A907(E), based on copper content, most 1600F (comon grey colored permatex hi temp) and 1800F (copper colored Permatex "copper" Antisieze) A/S compounds pass 907. A turbo "might" see 1800f prior to failure, 1600f is the max norm AT the turbine of the turbo. So the 2400f Ag based A/S is way overkill for a stock 80. Regardless, Mr. T chose copper nuts and no A/S for good reason, it's easily serviced regarless of *fastener* corrosion.
Not true. Neither porsche or audi use A/S on exhaust hardware or turbo hardware. I only point out that A/S is mostly an aftermarket thing, it's not commonly used in production vehicles on exhaust systems (or anywhere else for that matter). One of the lone exceptions is the O2 sensor threads. And I regularly find 02 sensor holes galled *with* A/S applied, and salute Mr. T for the flange type mounting with copper nuts. It really solves the 02 sensor galling problem, more than A/S does.
A copper nut is antiseize by definition, you heat it and it will release from steel quite easily. I just did it on my 12yo 02 sensors, and the 10mm wrench spun, that's how worn the nuts were. I heated them up once (see archives) and removed them with a pair of pliers.
I see nothing wrong with copper nuts and *no* antisieze compound. It's how the factory delivered the truck, and IME copper nuts releases much better over time than any steel nut.
ST
ST
Copper nuts must be an early trucks thing, my '96 has standard steel?
Mine too. Well it did, I replaced with brass - got them out of a stud and nut kit at the local auto store, didn't want to waste time driving into town to the VW shops ;)
... Thread-gone-nuts (tm) on $3 worth of nuts, when really, 8x1.25 is about the only significant factor to *fitment*. To the original post, lots of options available to fit that 8x1.25 stud. You need 4 of whatever you choose to purchase.
ST
