I did a search and found too many hits to decipher to find issues similar to mine.
On my 2004 LC, I noticed a faint coolant smell after driving and that my coolant overflow tank was nearly empty. The LC never overheated. I took it to the shop (high end shop, but not LC specialists) and they replaced heater hoses at the rear of the engine compartment and the thermostat housing (which had a tiny bit of pink crust on it). Expensive job, and my LC still exhibits the same symptoms (maybe a little less, but still present). Here are some things I've noticed that may help figure this out:
-- Engine oil looks fine (i.e., not a milkshake)
-- No smokey (or steamy) exhaust
-- I have been using my heat a bit
-- I feel like I smell the coolant more on the right side (but this may just be me being crazy)
-- I don't know what the "Ts" are and/or whether they've been replaced. I don't, however, see any pink crust on visible parts of the engine. Would replacing Ts be part of doing the heater hoses?
-- My commute is only 4-5 miles each way and, I don't think I've driven much more than that at any time since I've noticed this issue.
Any help you guys can give to help diagnose this (or to help me tell mechanic what to look for as I'm not very good DIY) would by greatly appreciated. Thanks!!
