Coolant leak
Australia
Hello All,
Need suggestions on where you think my coolant leak is coming from. The leak is coming from where the gearbox connects to the motor 1HZ
The photo below shows the engine sump on the r/h side
Cheers
Hmm!
Lay some cardboard down in strategic locations, ideally to separate hoses/piping from anything head and block related. Royal pia because coolant flows . Good luck.
If its running down the oilpan, it must be close to the firewall, I guess.
Heating is the only device running coolant in that area, other than frost plugs and drain cock. Check heating outlet on engine block and control valve.
Other than that Squah advised on already. But you better dry off the spill before . Good luck.
Whoah.... someone took my old user name... :lol:
I was about to write something wondering why "Beno" need help with a leak. Figured Onur would not need help.
Send your truck to Onur, he will take care of it.
That will most likely be the big welch plug behind the flywheel. Double check the heater hoses first
